Steven DiStefano Tue, 08/10/2010 - 12:00
  • Blue, 1500 points or more
On the phone there is the Setup Button, then Device Administration; then I see "Factory reset", but that will be everything I would think....
JonesT2cisco Mon, 09/13/2010 - 10:15
Unfortunately, to get to "Reset to Factory Settings", I have to know the admin password.  The original person is gone, so we need to completely start over.  Is there a button or something?  What do I do?
Alberto Montilla Tue, 09/14/2010 - 08:14
  • Cisco Employee,
Dear Sir;
This is not possible. The whole reason for the password is to provide security. If factory reset is protected by password, then not possible to change/reset.
Alberto
chromiszach Mon, 09/27/2010 - 14:12
This is not true... Try this.
Open a browser. Enter the following web address: http://IPAddress/admin/advanced
Where the IPAddress is the phone's IP.
This *should* let you into the interface without requiring you to enter any password information. You can then go to system configuration and strip out the user password. Submit the change and then you can factory reset the phone from the phone's interface.
Hope that helps. It worked for me using version 7.1.7.
Zach
uscwcole710 Mon, 01/23/2012 - 12:15
While power cycling the SPA Phone, after you see the Cisco trademark symbol disappear and while it is going through it's animations, press the speaker button three times.  That will reset the phone.
