08-10-2010 12:07 PM - edited 03-04-2019 09:22 AM
Hello All,
As the heading says
I am looking to change the IP on one of my loopbacks
Current Settings :
interface Loopback4
ip address 206.186.192.209 255.255.255.255
Desired Setting :
I need to change the Ip to 206.186.197.134/32 on the above mentioned loopback.
Can any of you please suggest the simplicit way to do that. Also will this cause any disaruption in service.
Thanks in advance,
Soofi!
Solved! Go to Solution.
08-10-2010 12:11 PM
soofiahtesham wrote:
Hello All,
As the heading says
Current Settings :
interface Loopback4
Desired Setting :
Thanks in advance,
Soofi!
router(config)# int loopback 4
routerconfig-if)# ip address 206.186.197.134 255.255.255.255
as for disruption depends on what it is used for. Also bear in mind if you are advertising this loopback into a routing protocol you may need to add the new IP under your router config.
Jon
08-10-2010 12:11 PM
Hello All,
As the heading says
Current Settings :
interface Loopback4
Desired Setting :
Thanks in advance,
Soofi!
Jon
08-11-2010 02:14 AM
Simply writing a ip configuration commads for any interface of router.
Router>en
Router#conf t
Router(Config)#int loopback4
Router(Config-if)#ip address
Router(Config-if)#no shut
this will configure any loopback ip at any point of time.
Vinod Agrahari
08-11-2010 06:19 AM
vinod.agrahari wrote:
Router>en
Router#conf t
Vinod Agrahari
removed
