multiple hosts in policy nat
Answered Question
Aug 10th, 2010
how can i do this:
access-list AL200 permit ip host 172.16.11.27 Units 255.255.192.0
access-list AL200 permit ip host 172.16.11.27 Routers 255.255.255.248
access-list AL200 permit ip host 172.16.11.27 host IMSA
access-list AL200 permit ip host 172.16.11.27 host EIserver
access-list AL200 permit ip host 172.16.11.26 host GGSNnew
access-list AL200 permit ip host 172.16.11.26 Meterpool 255.255.240.0
static (production,outside) 172.16.11.200 access-list AL200 0 0
Correct Answer by Andrew Ossipov about 6 years 8 months ago
You can policy PAT traffic from just two hosts to the given IP address (this will only work outbound), but you cannot do it with the configuration above. The policy PAT would look somewhat like this:
nat (production) 11 access-list AL200
global (outside) 11 172.16.11.200
Andrew
Overall Rating: 5 (1 ratings)
Kureli Sankar Tue, 08/10/2010 - 14:13
  • Cisco Employee,
You are unable to do this in PIX506 - 6.x code?
-KS
RvanRouwendaal Tue, 08/10/2010 - 13:55
so what you are trying to say it is not possible at all? i dont understand could you give me some directions?
Correct Answer
Andrew Ossipov Tue, 08/10/2010 - 13:59
  • Cisco Employee,
Andrew
RvanRouwendaal Tue, 08/10/2010 - 14:05
thank you so much this worked as a charm.
What kind off problems could this give?
Andrew Ossipov Tue, 08/10/2010 - 14:10
  • Cisco Employee,
Glad it helped! It is a fairly standard NAT configuration, so it should work without problems. The only caveat is that you cannot initiate reverse connections from outside between the hosts and subnets identified in the ACL.
Andrew
RvanRouwendaal Tue, 08/10/2010 - 14:17
I dont really understand your last post. Does this mean no traffic could come in on 172.16.11.200?
Andrew Ossipov Tue, 08/10/2010 - 14:19
  • Cisco Employee,
That is correct, you cannot initiate inbound connections to 172.16.11.200. This is the main property of dynamic PAT. In order to initiate inbound connections, you must have one-to-one mapping with either one IP per inside host or one port per inside service (static PAT).
Andrew
RvanRouwendaal Tue, 08/10/2010 - 14:23
hmmmm thats gonna be a problem cause these rules initiate from both sides:
access-list AL200 permit ip host 172.16.11.26 host TMGGSNnew
access-list AL200 permit ip host 172.16.11.26 TMmeterpool 255.255.240.0
i there a work-around for this?
Andrew Ossipov Tue, 08/10/2010 - 14:26
  • Cisco Employee,
The workaround is to dedicate one mapped (public) IP to each inside (private) host. I.e.:
access-list AL201 permit ip host 172.16.11.26 host GGSNnew
access-list AL201 permit ip host 172.16.11.26 Meterpool 255.255.240.0
static (production,outside) 172.16.11.201 access-list AL201
RvanRouwendaal Tue, 08/10/2010 - 14:29
172.16.11.201 doesnt have access to the VPNs... so thats a no go...
The problem is that on the old server we had 2 environments which went to 3 VPNS... all using the 200 NAT. Now we made two new server (1 goes to 2 vpns and 1 goes to the third). They still need to do so with the 200 NAT
