CAD 7.5 Upgrade Question
Answered Question
Aug 10th, 2010
Does anyone know if when upgrading CAD from 7.2 to 7.5(6) the client desktops are simply prompted that a "newer version is now available" and asked to update their desktop vs. having to push completely msi packages to the desktop?
Overall Rating: 5 (1 ratings)
Correct Answer
I would use 7.6(1) rather than 7.5.(6).
But yes - you can choose to have update notification on or off.
We turn normally it off, because agent machines are typically "User Rights" only so one can't install anyway. Better to have SMS push the new client or the update (SR).
Geoff
gall00004 Tue, 08/10/2010 - 14:13
Thanks for the response.  Running ICM 7.5(8) with CTIOS 7.5(8), CAD 7.6(1) is the better version to go to?  With 7.6(1) I believe you still need to first apply CAD 7.5(1) correct?
