CSM - ACE Migration
Aug 10th, 2010
I have a pair of 6509's with CSM and SSL modules. We are migrating these to ACE modules in a few days. I have the configuration (except for the interfaces) configured on the ACE, including exported/imported SSL certificates/keys. By not configuring the interfaces with service-policy, the VIP's nor the server IP addresses can conflict with the CSM.
Also, the supervisor config has already been set up to include the client and server vlans for the service linecard. That connectivity has been established, however, I will be changing the client side interface vlan to the one that the CSM was using as the existing one is temporary.
My plan is as follows:
1. Remove the vlan statements for server and client from the supervisor (from config mode, csm mod #).
2. Power down CSM and SSL modules from supervisor.
3. Session into ACE. Modify inteface vlans for both client and server side to use the IP addresses from the vlan server and vlan client configs.
At this time, the servers should begin to appear in the ACE modules' ARP table and the client VIP's should start responding.
Now, what or how do we clean up the rest of the CSM configuration in the supervisor?
If you see any flaws in this plan, please let me know.
Thanks in advance for your assistance.
yushimaz Mon, 08/16/2010 - 20:09
  • Cisco Employee,
Regarding clean up the CSM configuration, please refer to the following discussion.
Erasing CSM configuration
https://supportforums.cisco.com/message/446477
You can remove CSM config with 'no mod csm [slot#]' command, where you have
to remove all vserver config before you issue this command as Phil said in above
discussion. (I checked with 12.2(18)SXF13 and the result was as below.)
#conf t
(config)#no mod csm 3
% Remove vserver before unconfiguring slot 3  <<==
(config)#
(config)#mod csm 3
(config-module-csm)#no vser test
(config-module-csm)#end
#coff t
(config)#end
Regarding migration step, probably it works fine.
When I migrate from CSM to ACE in my lab, I use the following step.
1) issue 'no power enable' command on the sup for the CSM
2) issue 'svclc vlan-group' command on the sup for the ACE module
#conf t
Enter configuration commands, one per line.  End with CNTL/Z.
(config)#no power enable module 3
Aug 17 00:24:29.643: %C6KPWR-SP-4-DISABLED: power to module in slot 3 set off (admin request)
(config)#end
#conf t
(config)#svclc vlan-group 1  771,772
(config)#end
## sup config for ACE in slot4
#sh run | i svclc
svclc autostate
svclc multiple-vlan-interfaces
svclc module 4 vlan-group 1
## CSM config in slot 3
#sh run mod 3
Building configuration...
Current configuration : 458 bytes
module ContentSwitchingModule 3
vlan 771 client
  ip address 192.168.71.250 255.255.255.0
vlan 772 server
  ip address 192.168.72.250 255.255.255.0
real SV1
  address 192.168.72.11
  inservice
real SV2
  address 192.168.72.12
  inservice
serverfarm SF
  nat server
  no nat client
  real name SV1
   inservice
  real name SV2
   inservice
vserver TEST
  virtual 192.168.71.100 any
  serverfarm SF
  persistent rebalance
  inservice
end
#conf t
(cnfig)#mod csm 3
(config-module-csm)#exit
(config)#no mod csm 3  <<== clear config
(config)#end
*Aug 17 00:31:07.619: %SYS-5-CONFIG_I: Configured from console by console
#sh run mod 3
Current configuration : 5 bytes
end
## ACE config
ACE20/Admin# sh run
Generating configuration....
hostname ACE20
boot system image:c6ace-t1k9-mz.A2_3_1.bin
access-list all line 8 extended permit ip any any
rserver host sv1
  ip address 192.168.72.11
  inservice
rserver host sv2
  ip address 192.168.72.12
  inservice
serverfarm host sf
  rserver sv1 80
    inservice
  rserver sv2 80
    inservice
class-map match-all vip-l3
  2 match virtual-address 192.168.71.100 any
policy-map type loadbalance first-match lb
  class class-default
    serverfarm sf
policy-map multi-match client-vips
  class vip-l3
    loadbalance vip inservice
    loadbalance policy lb
    loadbalance vip icmp-reply
access-group input all
interface vlan 771
  service-policy input client-vips
  no shutdown
interface vlan 772
  no shutdown
Yuji
aanelso1 Tue, 08/17/2010 - 04:52
Your assistance is much appreciated. I will give these instructions a go after submitting change request.
CONFIDENTIALITY NOTICE
This email message, including any attachment(s), is for the sole use of the intended recipient(s) and may contain confidential information. Any unauthorized review, use, disclosure or distribution is strictly prohibited. If you are not the intended recipient, please immediately contact the sender by email. Thank you
Al Nelson Jr.
ConocoPhillips
Analyst - Global Web Infrastructure
614-10 IC Building
420 South Keeler
Bartlesville, OK 74006
Phone: 918-661-0943
Cell: 918-841-2814
