Not Authorizationed? No reset, No Admin Access
Aug 10th, 2010
I get a 404 and a pop-up "not authorizationed" (exact spelling) when I try to open the web-based utility from a wired connection.  Either through the router using DHCP or with the client configured to the same subnet.  No access. None.  30-30-30 reset does nothing, settings remain intact.
This is the second time this has happened, in two separate locations, with separate configurations, with separate WAP200 AP's
I have returned one for a replacement and had the same result a week later.
I can not be the only one.
