DPD one way on Site to Site VPN using ASA's
Aug 10th, 2010
I have 2 ASA5505's configured for a site to site tunnel which is all working great.  The link is via cellular modem and goes down frequently.  One side spots the loss of connectivity via DPD but the other does not.  This means the connection does not come back because the SA's are not torn down on the side DPD seems to not be working.  Identical configurations, identical firewalls, different behaviour!  Can someone give guidance?
I think I found a bug...I had a continuous ping running between 2 laptops on the local area networks.  If the ping was running, DPD on the side the ping was sourced from failed to realize the cloud and broken.  Without the ping DPD worked as advertised.  No other traffic types seemed to have this effect.  This is a reproduceable issue...
where are the cisco developers when you need them!
