Problem with the firewall
Aug 10th, 2010
Hi All,
I have one 3750 and one 2960 switch.
My 3750 act as the core switch.
I configure the 3750 to route to the firewall in order to have internet connection.
But the problem is i can ping the firewall but i can't connect to the internet.
what will be the possible reason and how will i configure that.
Nagaraja Thanthry Tue, 08/10/2010 - 17:42
Have you configured default route in the switch? If not, please try the following:
Switch#configure terminal
Switch(config)#ip routing
Switch(config)#ip route 0.0.0.0 0.0.0.0
Also, please make sure that the firewall has NAT rules configured for your LAN subnets.
Hope this helps.
NT
nelba_aldovino Tue, 08/10/2010 - 17:47
yes i have configured the ip route on the 3750.
the firewall that i used is the linksys wrt610N.
It has default NAT but i also configure static route on the linksys.
I can ping the LAN ip of the linksys but i can't ping the internet ip of it.
what will i do....
thank you!
nelba_aldovino Tue, 08/10/2010 - 17:58
here's the configuration of the linksys:
Internet ip address: 203.177.217.229
subnet mask:         255.255.255.248
Gateway     :          203.177.217.225
DNS:                    203.177.255.10
LAN IP:     172.25.74.71
Subnet:      255.255.255.0
nelba_aldovino Tue, 08/10/2010 - 18:06
here's the configuration of my switch 3750
ip subnet
ip routing
no file verify auto
spanning-tree mode pvst
spanning-tree vlan 2-6 priority 0
vlan access-map ADMIN 10
action forward
match ip address ADMIN TO_SERVERS GLOBAL
vlan access-map PRODUCTION 10
action forward
match ip address PRODUCTION TO_SERVERS GLOBAL
vlan filter ADMIN vlan-list 4
vlan filter PRODUCTION vlan-list 5
vlan internal allocation policy ascending
interface GigabitEthernet1/0/1
switchport mode trunk
interface GigabitEthernet1/0/2
interface GigabitEthernet1/0/3
interface GigabitEthernet1/0/4
interface GigabitEthernet1/0/5
interface GigabitEthernet1/0/6
interface GigabitEthernet1/0/7
interface GigabitEthernet1/0/8
interface GigabitEthernet1/0/9
interface GigabitEthernet1/0/10
interface GigabitEthernet1/0/11
interface GigabitEthernet1/0/12
interface Vlan1
no ip address
interface Vlan2
ip address 172.25.74.64 255.255.255.0
interface Vlan3
ip address 172.17.3.125 255.255.0.0 secondary
ip address 172.25.72.64 255.255.255.0
interface Vlan4
ip address 172.25.73.64 255.255.255.0
interface Vlan5
ip address 172.25.71.64 255.255.255.0
interface Vlan6
no ip address
ip classless
ip route 0.0.0.0 0.0.0.0 172.25.74.71
ip http server
ip access-list extended ADMIN
permit ip any 172.25.73.0 0.0.0.255
ip access-list extended GLOBAL
deny   ip any 172.25.74.0 0.0.0.255
deny   ip any 172.25.73.0 0.0.0.255
deny   ip any 172.25.72.0 0.0.0.255
deny   ip any 172.25.71.0 0.0.0.255
permit ip any 172.25.74.0 0.0.0.255
ip access-list extended PRODUCTION
permit ip any 172.25.71.0 0.0.0.255
ip access-list extended TO_INTERNETD
permit ip 172.17.0.0 0.0.0.255 host 17.25.74.90
ip access-list extended TO_SERVERS
permit ip any 172.25.72.0 0.0.0.255
permit ip host 172.25.71.66 host 203.177.217.229
radius-server source-ports 1645-1646
Nagaraja Thanthry Tue, 08/10/2010 - 18:14
WRT610N (or most of the SOHO routers) are not capable of handling multiple subnets and they do not NAT subnets that are not directly connected to their inside (LAN) interface. Please try changing subnet mask of WRT610n to /16. This will ensure that the WRT610N will view entire LAN behind the 3750 as directly connected to its LAN.
Subnet: 255.255.0.0
Hope this helps.
NT
Nagaraja Thanthry Tue, 08/10/2010 - 18:36
In that case, you need to either get a different device or you need to change your addressing scheme on the VLANs so that all VLAN's will have 172.25.74.x address.
interface Vlan2
ip address 172.25.74.65 255.255.255.192
interface Vlan3
ip address 172.25.74.1 255.255.255.192
interface Vlan4
ip address 172.25.74.129 255.255.255.192
interface Vlan5
ip address 172.25.71.193 255.255.255.192
This will work as long as you have less than 60 clients in each VLAN. You need to change your DHCP scopes accordingly and also change the access-lists.
Hope this helps.
NT
