Clientless SSL VPN Portal Customizaiton fails on 5510
Aug 10th, 2010
I am trying to customize a web VPN portal on my 5510 but I get errors whenever I try to add a customization object.  Running ADSM 6.1(5)51 on ASA 8.0(5).  The error I get when I try to apply a newly created customization object is:
[ERROR] export webvpn customization DfltCustomization disk0:/tmpAsdmImportFile2090698426
export webvpn customization DfltCustomization disk0:/tmpAsdmImportFile2090698426                            ^
% Invalid input detected at '^' marker.
[ERROR] import webvpn customization test disk0:/tmpAsdmImportFile2090698426
    % copying 'disk0:/tmpAsdmImportFile2090698426' to a temporary ramfs file failed
[ERROR] delete /noconfirm disk0:/tmpAsdmImportFile2090698426
%Error deleting disk0:/tmpAsdmImportFile2090698426 (No such file or directory)
Tried revert webvpn all but I get error on that as well:
Result of the command: "revert webvpn all"
%ERROR: ifs_rm_dir_rec: unknown type of file `disk0:/csco_config/97/customization/86D3828A0A0EB0FFA3B55870AAA43E4F'
Any ideas?
Joe
gurdsing Wed, 09/01/2010 - 14:42
I think this is related to bug ID : CSCsy77628.
I am seeing several cases where the resolution/workaround was to format the flash. Can you try that and let me know?
Guru.
planning-contro... Sun, 09/23/2012 - 02:34
I have simialr issue of not finding theDfltCustomization object when I treid to create any new Customization object. How can I export file. where can I find theDfltCustomization object to export.
Javier Portuguez Sun, 09/23/2012 - 05:31
  • Red, 2250 points or more
As mentioned by Guru, the recommended action is to format the flash: memory.
Sometimes some webvpn files get corrupted resulting in missing DfltCustomization objects or import errors.
Once you format it, it should work fine.
Thanks.
Portu.
