VPN groups
Aug 10th, 2010
I am running asa804-k8.bin on ASA 5520.
License is: VPN Plus
We use VPN with cisco VPN-client.
for user authentication i am using tacacs server.
for example:
vpn 1:
ASA:
VPN Group                       :Group_A
PSK                                 :Very_Secret_A
Authentication server group: Group_A
                              Server: Tacacs
Tacacs:
group of users: Group_A
        User: user1
Password: Password2
vpn 2:
ASA:
VPN Group                       : Group_B
PSK                                 : Very_Secret_B
Authentication server group: Group_B
                              Server: Tacacs
Tacacs:
group of users: Group_B
        User: user2
Password: Password2
Problem is: if User1 know the PSK of Group2, he can successfully use VPN2. Same for user1.
Is there any option to disable user1 for Grpou_B???
jan.nielsen Sun, 08/29/2010 - 13:15
  • Gold, 750 points or more
There is a feature called group lock which does what you wan't, look for the option called Class/25, in there you put OU=; without the brackets, and the asa will only allow that user to login to that specific group policy. However i don't know if it works with tacacs, as it normally is sent as radius attributes
