Problem with Agent based campaign
Aug 11th, 2010
Dear All
I am facing an issue with agent based campaigns on a multi dialer enviornment. We have three dialers running and IVR based campaigns work just fine on them.
Agent based campaign only works when dialer 1 is active.
When any of the other 2 dialers are active agent based campaign does not work. IVR campaign work fine on each dialer.
I have traced the logs for the malfuctioning dialer and found.
     The dialer try to allocate a port and is unable to do so......and does the same over and over again.
Can anyone please help.
Md. Rashedul Alam Wed, 08/11/2010 - 21:20
hassanalirazi Wed, 08/11/2010 - 23:43
Ill do the best i can to help you out.
tell me are you in a live or a lab eviornment? Are you able to agent based campaigns?
Md. Rashedul Alam Thu, 08/12/2010 - 02:29
Thanks for your reply. This is on my lab. yes i have configured only one agent based campaign. it was working fine but i have deleted coz i was thinking this might me the problem for IVR camp. but still no luck.
So guide me how can i run the IVR camp.
