4402-50 ap question
Answered Question
Aug 11th, 2010
If the controller support 50 ap's, and there are actually 58 ap's, if I disable 8 administratively, will i then see the other 50 that are up ?
I guess the question is if the controller manages 50 ap's regardless of status, or 50 active ap's ?
NM
Correct Answer by dancampb about 6 years 5 months ago
No, a 4402-50 controller can only have 50 APs joined to it.
Overall Rating: 5 (1 ratings)
Correct Answer
dancampb Wed, 08/11/2010 - 06:24
Chieu Dinh Tue, 09/25/2012 - 12:33
AIR-WLC4402-50-K9 can only 50 APs joined to it? if I added more license on WCS to 50 more, can I still able to join more APs?
George Stefanick Tue, 09/25/2012 - 12:34
hi,
No the 4400 and WISM models are HARD count. They dont take licenses, if you purchase a 4402-50, 50 is all you get. If you purchased a 5508, 2504 or WISM2, these models allow licenses.
Hope that helps ..
__________________________________________________________________________________________
