sip g711a to cue, call dropped
Aug 11th, 2010
Hi all,
I have the issue where I cannot change g711a to anything else, due to the nature of the sip provider. How can I transcribe this so that the call stops being dropped?
Thanks.
mobilepc10 Wed, 08/11/2010 - 12:45
I've seen that post. I just don't know which bits to add, or which bits I should be adding.
Brandon Buffin Wed, 08/11/2010 - 12:49
  • Purple, 4500 points or more
You'll need the following, substituting your IP addresses, etc.
voice-card 0
dspfarm
dsp services dspfarm
sccp local Loopback0
sccp ccm 10.1.1.1 identifier 1 version 4.1
sccp
sccp ccm group 1
associate ccm 1 priority 1
associate profile 3 register mtp123412341234
dspfarm profile 3 transcode
codec g711ulaw
codec g711alaw
codec g729abr8
codec g729ar8
codec g729r8
maximum sessions 1
associate application SCCP
no shutdown
dspfarm
telephony-service
sdspfarm units 3
sdspfarm transcode sessions 4
sdspfarm unregister force
sdspfarm tag 3 mtp123412341234
ip source-address 10.1.1.1 port 2000
Brandon
mobilepc10 Wed, 08/11/2010 - 14:44
I get the following message, how do I overcome this?
This change requires SCCP to be in shutdown state.
Brandon Buffin Thu, 08/12/2010 - 05:18
"no sccp"
Sounds like you may have already had a transcoder configured?
Brandon
mobilepc10 Sat, 08/14/2010 - 03:36
A bit of configuration was there, but not much.
Can someone please help, possibly look at my config? Since tinkering with this, callers cannot hear me, but I can hear them. I still have the issue of voicemail dropped calls. I am pulling my hair out on this one. TAC has been a bit useless, about to get the case reassigned. If I could get some help in the mean time, that would be great.
antyeung Tue, 08/17/2010 - 00:54
  • Bronze, 100 points or more
Can you provide the TAC case number that you have opened to track this issue?
Attach your configurations and I can see if I spot anything out of the normal.
Anthony
