DRS issues with Unity Connection 7.1.5
Answered Question
Aug 11th, 2010
Hi all,
We're having some Issues with the DRS Backup of a CUCM BE 7.1.5 System.
System Version is 7.1.5.10000-12.
When selecting the CUC Feature in DRS the backup fails,
The Error I get is the following:
Failed to initiate backup. Server [ZURCM01], component [CLM] requires component [PLATFORM] to be registered.
When deactivating the CUC Feature the Backup runs normally.
Any ideas how to fix this?
Thanks for all your Help
BR
Alex
Correct Answer by Bradford Magnani about 6 years 5 months ago
Hi Alex,
You may want to try the steps in the below defect and see if it helps you any:
http://tools.cisco.com/Support/BugToolKit/search/getBugDetails.do?method=fetchBugDetails&bugId=CSCsw64366
Hope that helps,
Brad
Overall Rating: 5 (1 ratings)
Alex Bagaglio Wed, 08/11/2010 - 07:51
Hi Brad,
Thanks for your Help.
The Solution was to Re-create the ipsec Cert.
CUC now gets backed up correctly!
Thanks again
Alex
Related Content
