Configuring redundant VPN connection between two sites
i have two sites connected using two redundant WAN connections, and i am going to configure two VPN tunnels as a redundant tunnels.
my question is how to configure two VPN tunnels between the two sites, so that when the first tunnel goes down the second WAN connection becomes up and tunnel as will.
-the two sites connected using routers.
Xiang Hong Ange... Wed, 08/11/2010 - 06:32
Hi ,
If it is site-to-site VPN, just need two "set peer x.x.x.x" command.. the first one is the primary site, and second one is the back up site peer address. once the first one goes down, it will switch to 2nd site.
-Angela
