AD SSO Agent Login (Invalid username and password)
Aug 11th, 2010
Hello;
I updated my NAC from 4.7.1 to 4.8.0 and so far i had some hicckups but I am getting over them.. One of the issue I am facing right now is that no one cannot login to the NAC they all are comnig back as Invalid username and password.  I need some help here if anyone have ever run into this problem before.
I have check the AD SSO and it is started...
Joel
Faisal Sehbai Fri, 08/13/2010 - 04:41
Update on this. Joel figured out that it was a bad password on his AD account.
Documenting solution.
rossiterj Wed, 06/15/2011 - 18:47
HI Faisal,
I'm getting the same exact error. Which AD account had a bad password?
John
