connect two 3560 switches togather
Answered Question
Aug 11th, 2010
Hi Experts
I have two 3560 switches which i would like to connect through GBIC ports
please let me know what commands required to config these ports lets assume connecting ports 28 togather
any help would be appreciated
Asif
Correct Answer by Nagaraja Thanthry about 6 years 7 months ago
Yes, once you trunk, you can use VLAN 301 and 310 in the second switch. You
need to enable those vlans on the switch by assigning ports to those VLANs.
The trunk will not affect rest of the operations.
Hope this helps.
NT
Overall Rating: 5 (1 ratings)
Nagaraja Thanthry Wed, 08/11/2010 - 07:37
  • Cisco Employee,
If you are having a flat VLAN structure i.e. only VLAN 1 in the entire network (on both switches), then you can just connect those two ports normally and the switch will take care of the rest. If you have multiple vlans, then you need to configure trunk:
Interface gi 0/28
Switchport trunk encapsulation dot1q
Switchport mode trunk
Exit
This will ensure that both switches communicate through all VLANs.
Hope this helps.
NT
akhanwaterloo Wed, 08/11/2010 - 07:48
Let me just give some more on my network so it would not effect or impact
switch1 - ports 1 and 2 are uplink ports for data(301) and voice(310) vlans respectively coming from HP 3550 router
              ports 3-23 are access ports
              port 24 for switch management in default VLAN1
now te scenario is bring a new switch2 all ports will be access ports
as per your advise
attach the gig0/28 ports with fibre and config the port 28 with
Interface gi 0/28
Exit
now the vlans 301 and 310 will be available and can be used in switch2 as well ?
that trunk would not have any impact?
thanks once again
Asif
Correct Answer
Nagaraja Thanthry Wed, 08/11/2010 - 07:57
  • Cisco Employee,
Hope this helps.
NT
