hi,
I am trying to setup a guest WLAN using a local controller and a controller in my DMZ using the mobility-anchor configuration.
Ideally I'd like to use an external DHCP server in my DMZ, but for now, I'd be happy getting the local DHCP server on the DMZ controller working.
Local Controller config
Configured mobility-groups, verified mobility group is working
Created WLAN called "guest" - assigned it to the management interface.
Have tried the following with regards to DHCP on this WLAN.
Set it to "override" and specified the DMZ controller's mangement interface
Set DHCP to "assignment required" and specified the DMZ controller's management interface for the DHCP server for the local controller's management interface
Left DHCP server blank on the local controller's management interface
Setup the DMZ controller as the mobility anchor for the "guest" WLAN
DMZ controller config
Created a dynamic interface called "guest" associated to the "guest" WLAN
Setup mobility anchor for the "guest" interface, mobility-anchor = local controller
Created an internal DHCP server scope and enabled it
Have tried the following with regards to DHCP on the "guest" WLAN
Set DHCP to "assignment required" and specified the IP address of the controllers management interface as the DHCP server on the "guest" dynamic interface
Set DHCP to "assignment required" and specified the IP address of the controllers "guest" dynamic interface as the DHCP server on the "guest" dynamic interface
Set DHCP to "override" and specified the DMZ controller's management interface IP
Set DHCP to "override" and specified the DMZ controller's "guest" interface IP
After all this, my client still cannot get an IP address via DHCP. I verfiied the client is associating to the AP.
Lee
