jsirstin Wed, 08/11/2010 - 12:01
  • Cisco Employee,
Derek,
You are not missing anything. The ACE only allows you to create up to four authgroups per context.
Jim
derek wilson Thu, 08/12/2010 - 01:20
Jim - thanks for the fast response.
So If I have a context with 4 authgroups & then the customer has another endpoint that requires a new 5th or 6th authgroup whats the way round that?  Making another context is very long winded & a waste of resource.
Im running code A2 2.3.
thanks
jsirstin Thu, 08/12/2010 - 08:27
  • Cisco Employee,
Derek,
Each authgroup can contain up to 4 CA certs. You could use the same authgroup in multiple ssl-proxy services. This give you the ability to have up to 16 CAs for client authentication per context.
Jim
