is there a migration path for unity connection 2.0 to unity full blown version 8?
is there a migration path for unity connection 2.0 to unity full blown version 8?thanks
Aaron Harrison
You can probably use COBRAS for this purpose.. though Unity Connection 2 doesn't seem to be listed as supported... http://www.ciscounitytools.com/Applications/General/COBRAS/COBRAS.html
Basically export everything from a supported source server, build your new server and selectively import users and other elements (call handlers etc).
You can try the export at least... that's non-intrusive.
Aaron
Aaron Please remember to rate helpful posts to identify useful responses, and mark 'Answered' if appropriate!
The reason CUC 2.x isn't listed is because it's not (and never will be) supported by COBRAS - the help file for COBRAS explicitly states this in a few spots just to be extra clear - I get this question a lot.
Short version is the interfaces to get at data from off box in 2.x was simply not there - 7.0(1) was the first major release that had all the plumbing in place for fetching everything you need for a migration tool like COBRAS.
The export wont let you extract data at all for versions prior to 7.0(1).
