View AP LED Status Command
Answered Question
Aug 11th, 2010
I am trying to view the LED status of a 1131 AP joined to a WLC 2106 controller.  I ssh in to the 2106 controller and I go to >show ap ?.  I tried viewing the output of pretty much every one of those commands but I am having trouble finding anything that shows me the current LED status of an AP.  I am trying to verify that the AP LED has gone back to green or blue from a previous orange color.  Any ideas on what command I should be using to get that information?  Thanks!  Mike
Correct Answer by George Stefanick about 6 years 7 months ago
I had the same issue once. I t was power related. Check both radios and see if they show enabled (but disabled). Since one radio is up, say 802.11g check your 802.11a radio. Disable this radio and see if the orange goes away.
Correct Answer by Leo Laohoo about 6 years 7 months ago
Maybe the AP that's orange is the wrong AP.  Are you sure it's only orange and no other color?  Orange/Red means that the AP is in the bootup process or in ROMmon (and shouldn't show up in the "sh ap summary" result).
If your AP shows up in the command "sh ap summary" then it's either green or blue.
Overall Rating: 5 (3 ratings)
Correct Answer
Leo Laohoo Wed, 08/11/2010 - 15:53
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 LAN, Wireless
Michael MacKenna Wed, 08/11/2010 - 16:50
No, I am afraid that is incorrect.  My AP shows up in the results of "sh ap summary" but the LED on the AP is most definitely orange.
Correct Answer
Leo Laohoo Wed, 08/11/2010 - 17:05
  • Hall of Fame,
    2017 LAN, Wireless
Michael MacKenna Wed, 08/11/2010 - 17:52
Yep, I am sure.  I stood there and stared at it for about 30 seconds while scratching my head.  I am not really sure why it is orange.  The only post I could find for solid orange/amber related to incorrect power state injector setting.  I did a complete clear config on that AP and set it back up and its still orange.  The AP seems to be functioning just fine.  It shows ten clients connected to it.  The only other theory I have is that the max client connection is 12 so maybe it is orange because it is close to the max client count.  Other than that I am at a loss.  I am sure it is the correct AP.  There are only three on that controller and the other two are up and functioning also.  Thanks, Mike
Correct Answer
George Stefanick Thu, 08/12/2010 - 09:33
  • Purple, 4500 points or more
  • Community Spotlight Award,
    Best Publication, October 2015
Michael MacKenna Fri, 08/13/2010 - 07:50
I am so dumb.  I had another controller in that building and an AP mislabeled.  Turns out it was that I was looking at the wrong AP that was on a totally different controller.  The orange was there because an AP that used to be on an injector was now on POE and the power state was then not correct on the config of that AP.  Thanks for all the help.  I have the issues resolved now.
Never did get an answer to find a way to verify LED color via a command, apparently you can't do that on the 2106 controller.
Related Content
