08-11-2010 09:24 AM
I have a new ASA I just setup for VPN access just like all the other ASA's I have ever setup.
The VPN client connects just fine, gets an IP, is able to ping devices on the corporate network.
I have compared it to other ASA's I have setup that work. I can't see the issue.
3 things:
I am unable to ping the LAN interface of the ASA when VPN'ed in.
When I do a mturoute.exe to an inside IP it shows an MTU of only 196 when I use the Cisco VPN Dialer.
When I use the Shrewsoft VPN client I can set the MTU to 1380. When I do a mturoute.exe to an inside IP it shows 1380.
I am thinking because it doesn't respond to a Ping on the LAN of the ASA that the MTU path discovery doesn't work.
Bert
Solved! Go to Solution.
08-11-2010 11:42 AM
apologies for repeated postings but this is what you need to do
From a Windows device use this: C:\> ping -f -l packet_size_in_bytes destination_IP_address.
The -f option is used to specify that the packet cannot be fragmented. The -l option is used to specify the length of the packet. First try this with a packet size of 1,500. For example, ping -f -l 1500 192.168.100. If fragmentation is required but cannot be performed, you receive a message such as this: Packets need to be fragmented but DF set.
missed -f in my last post
# can you try from your command prompt
ping -f
so it sends a ping of 1380 bytes
so you should see something like this if it is not getting through
C:\Documents and Settings\jathaval>ping -f 4.2.2.2 -l 1380
Pinging 4.2.2.2 with 1380 bytes of data:
Packet needs to be fragmented but DF set.
08-11-2010 11:20 AM
"management-access
Naman
08-11-2010 11:29 AM
management-access inside allowed me to ping the Interface but that doesn't solve the MTU issue. The mturoute.exe still shows 196 for going through the ASA.
Bert
08-11-2010 11:22 AM
# do you have command
ping
08-11-2010 11:36 AM
can u try a ping with mss
ping
i think this should pass
08-11-2010 11:42 AM
ping -f
08-11-2010 12:26 PM
Here are my ping results. First my setmtu.exe is set to 1300.
C:\>ping -f bertman2 -l 1380
Pinging bertman2.somedomain.com [10.18.178.62] with 1380 bytes of data:
Ping statistics for 10.18.178.62:
Packets: Sent = 4, Received = 0, Lost = 4 (100% loss),
C:\>ping -f bertman2 -l 1000
Pinging bertman2.somedomain.com [10.18.178.62] with 1000 bytes of data:
Request timed out.
Request timed out.
Request timed out.
Request timed out.
C:\>ping -f bertman2 -l 1272
Pinging bertman2.somedomain.com [10.18.178.62] with 1272 bytes of data:
Request timed out.
Request timed out.
Request timed out.
Request timed out.
C:\>ping -f bertman2 -l 169
Pinging bertman2.somedomain.com [10.18.178.62] with 169 bytes of data:
Request timed out.
Request timed out.
Request timed out.
Request timed out.
C:\>ping -f bertman2 -l 168
Pinging bertman2.somedomain.com [10.18.178.62] with 168 bytes of data:
Request timed out.
Request timed out.
Request timed out.
Request timed out.
C:\>ping -f bertman2 -l 1273
Pinging bertman2.somedomain.com [10.18.178.62] with 1273 bytes of data:
C:\>ping -f bertman2 -l l00
Pinging bertman2.somedomain.com [10.18.178.62] with 0 bytes of data:
Reply from 10.18.178.62: bytes=0 time=309ms TTL=58
Reply from 10.18.178.62: bytes=0 time=311ms TTL=58
Reply from 10.18.178.62: bytes=0 time=308ms TTL=58
Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
Minimum = 308ms, Maximum = 311ms, Average = 309ms
It doesn't appear to be a Don't Fragment issue. Card MTU=1300 minus 28 bytes = 1272.
At ping -f bertman2 -l 1273 I get Packet needs to be fragmented but DF set.
but at ping -f bertman2 -l 1272 I get Request timed out.
It is only letting small packets through. ping -f bertman2 -l l00 works.
Any guesses. I am about ready to change the code to what is on all the othere ASA's and reboot.
Bert
08-11-2010 12:43 PM
Code upgrade fixed it.
Close threads.
Thanks for the help.
Bert
