08-11-2010 09:45 AM - edited 03-06-2019 12:26 PM
Is there a way I can force a 3845 to use DNS each time is does an NTP update? I'm trying to use the pool.ntp.org addrersses, but when I put them in the config, they resolve at that time. Since this is a public NTP service, these servers occasionally change, hence the need for ntp.org. Is there a way to have the router resolve the name each time?
Solved! Go to Solution.
08-11-2010 03:49 PM
Microsoft was a page that contains multiple NTP/SNTP server (Stratum 1 and Stratum 2) worldwide. In my configuration, I have multiple NTP servers and they all just take turn. Use the command:
ntp server 1.1.1.1
ntp server 2.2.2.2
ntp server 3.3.3.3
etc.
Y'get the drift.
08-11-2010 03:49 PM
ntp server 1.1.1.1
ntp server 2.2.2.2
ntp server 3.3.3.3
etc.
Y'get the drift.
08-12-2010 08:04 AM
As far as I know there is no way to have the IOS device use DNS to resolve each time it sends a request. It is standard behavior to resolve when the command is entered and to use the address going forward. If you are concerned about servers changing then the advice from Leo to configure multiple servers is a good solution. (and configuring multiple servers allows the IOS device to compare them and to identify any that are out of sync with the majority of the servers that you send requests to)
Rick
08-12-2010 03:30 PM
Thanks for the ratings. And thanks Rick.
