Upgrade PIX from 6.1(3) to 8.0(4)
Aug 11th, 2010
What would be the easiest way to do the upgrade?  I think I would have to do two interim upgrades first so is it possible to just reimage the device with 8.0(4) and apply the configurations from there?  Sorry for the newb question but I don't ever deal with updating firewalls.
Nagaraja Thanthry Wed, 08/11/2010 - 11:16
You could do it as long as you don't mind reconfiguring the device. Also, if
you do not have any conduits/alias commands, then it should be fine. You
might have to do some configurations based on the features you have enabled.
Hope this helps.
jnommensen Tue, 08/17/2010 - 13:51
Thanks!  We are good with memory etc requirements.  I think we're going to go with the incremental upgrades because it seems less likely for something major to go wrong.
