External Ringer needs to ring when blast group is called
Aug 11th, 2010
Calls come into the sytem and ring a blast group of 5 phone, I need the external ringer to ring at the same time.
I cannot use a shared line for this solution.
Bogen said that I need to provide them contact closure to accomplish this with the Bogen equipment currently installed.
How can I provide contact closure from an FXS or FXO port, I have both available.
Paging is currently working through an FXS port
Bogen Equipment
Brandon Svec Wed, 08/11/2010 - 13:04
I am surprised they didn't recommend a TAMB.  It can be set to create a contact closure when fxs port ring signal hits it: www.bogen.com/products/pdfs/telephonepagepdfs/TAMBs.pdf  It is normally used to take FXS/FXO port from the PBX and convert to page output, but a side effect is that it does a contact closure to mute music that might normally play through overhead speakers.  If you use it with and FXS port it doesn;t even need a power supply.
Can the blast group include an FXS port?  If so, this could work: http://www.vikingelectronics.com/products/pdf/pa-2a(sm).pdf
