08-11-2010 12:51 PM - edited 03-06-2019 12:26 PM
Hello.
I am doing a CISCO 1841 Router simmulation of VLAN on packet tracer.
I can create VLAN Database on the router. But how to insert FE interface on the VLAN?
In the interface FE0/0 there are no option to add switchport.
Router(config-if)#?
arp Set arp type (arpa, probe, snap) or timeout
bandwidth Set bandwidth informational parameter
cdp CDP interface subcommands
delay Specify interface throughput delay
description Interface specific description
duplex Configure duplex operation.
exit Exit from interface configuration mode
ip Interface Internet Protocol config commands
ipv6 IPv6 interface subcommands
mac-address Manually set interface MAC address
no Negate a command or set its defaults
shutdown Shutdown the selected interface
speed Configure speed operation.
Router(config-if)#
Is there any way to simulate real 1800 series IOS? I have check GNS3, but it did not support 1800 series.
Thanks.
Regards.
Sakibnaz.
08-11-2010 02:14 PM
You can't. The physical interfaces on a router are routed ports only.
Hope it helps.
08-11-2010 07:55 PM
You need a SW module, like HWIC-4ESW and HWIC-D-9ESW EtherSwitch Interface Cards.
