Help with HWIC-4SHDSL and distance limitations
Aug 11th, 2010
Does anyone know the distance limitations for the HWIC-4SHDSL?
I have a customer interested in using the bonding feature to get a data rate of over 8.448Mbps, but the data sheets don't show any details on distance limitations.
http://www.cisco.com/en/US/prod/collateral/modules/ps5949/ps7175/product_data_sheet0900aecd80581fa0.html
I'd appreciate any pointers.
Chris
paolo bevilacqua Wed, 08/11/2010 - 14:19
  • Hall of Fame,
    Founding Member
Distance also depends by wire gauge. Once you have collected all data, your cisco office system engineer can help you.
