08-11-2010 05:50 PM - edited 03-04-2019 09:23 AM
Is there a way to perform a ping sweep of an entire subnet on a router without using a third party utilitiy?
Thanks in advance.
Solved! Go to Solution.
08-11-2010 06:02 PM - last edited on 04-15-2022 01:08 AM by Translator
If the goal of the ping sweep is to see all the hosts on a particular subnet then the router arp table is a valuable resource.
Ping the broadcast address; then view the arp table. For example if the subnet in question is 192.168.1.0/24; then ping 192.168.1.255 from the router. Then execute a
show arp | inc
The results should be all mac/IP addresses on that subnet.
Chris
08-11-2010 07:00 PM - last edited on 04-15-2022 01:09 AM by Translator
You can try a TCL script like the following. Assuming your network is 10.1.1.0/24 (.1-.254)
tclsh
for {set i 1} {$i <= 254} {incr i} {
set var 10.1.1.
append var $i
ping $var rep 3 time 1}
ROUTER(tcl)#tclquit
Remember to use tclquit to exit the TCL prompt.
HTH,
jerry
show arp | inc
Chris
tclsh
set var 10.1.1.
append var $i
ROUTER(tcl)#tclquit
HTH,
jerry
