Problems when trying to surf the Internet through a SSL VPN tunnel
I have a small/big problem, I have a customer who have the need for the possibility to surf the internet through the SA500W when they are connected through a SSL VPN tunnel in to their network. I am not using a Split Tunnel. What I have seen until now, when you run IPCONFIG/ALL the default gateway for the SSL VPN IP settings is 0.0.0.0. Is this the problem and if so, how can this be solved?
Thanks in advance!
Brg
Niklas Eklov
