Dial plans and peers in CUCM 7
Aug 11th, 2010
dear any body
can you please tell me that how i can configure dial peers that i should call from one voip to another voip system in CUCM7 becouse in CME in routers the configuration was simple so can any body tell me how i can do this in call manager 7 please its need for me to learn this asap and to implement this in my office.
the CME configs was like this
dial-peer voice 1 pots
 destination-pattern 555....
 port 1/0:1
dial-peer voice 2 voip
 session target ipv4:192.168.1.1
but i dont know in cisco call manager 7 can any body help me pleaseeeeeee
with regards
http://www.ciscosystems.com/en/US/i/000001-100000/35001-40000/36501-37000/36849.jpg
Jonathan Schulenberg Thu, 08/12/2010 - 03:46
  • Cisco Designated VIP,
    2017 IP Telephony
You will need to create a SIP or H.323 trunk to the other system. Once that is configured you can add a route pattern and select the trunk as the off-net path to take. The route pattern will need to be in a partition that is included in the CSS of the calling party.
CME and UCM are two totally different platforms. Very little of what you understand about CME holds true in UCM and vice versa.
Waisudin Farzam Fri, 08/13/2010 - 21:55
dear Jonathan
thx for your reply but in this case do i need a Gateway or gatekeeper in between to do this task or cucm 7 can do this job
if i need can you send me a note of step by step
regards
