ANYCONNECT and SSL PORTAL
Aug 12th, 2010
Dear All,
I have CISCO ASA 5520 with AnyConnect Essential license. I have configured the web portal for login. Now I want to add intranet sites portal using remote access VPN --> clientless SSL VPN access --> portal --> Customization will that be feasible?
For me AnyConnect should work alone with the intranet portal enabled
Licensed features for this platform:
Maximum Physical Interfaces  : Unlimited
Maximum VLANs                : 150
Inside Hosts                 : Unlimited
Failover                     : Active/Active
VPN-DES                      : Enabled
VPN-3DES-AES                 : Enabled
Security Contexts            : 2
GTP/GPRS                     : Disabled
SSL VPN Peers                : 2
Total VPN Peers              : 750
Shared License               : Disabled
AnyConnect for Mobile        : Enabled
AnyConnect for Linksys phone : Disabled
AnyConnect Essentials        : Enabled
Advanced Endpoint Assessment : Disabled
UC Phone Proxy Sessions      : 2
Total UC Proxy Sessions      : 2
Botnet Traffic Filter        : Disabled
BR
Jennifer Halim Thu, 08/12/2010 - 01:15
  • Cisco Employee,
No, unfortunately with "AnyConnect Essential" license, you can only use the AnyConnect client (full tunnel mode).
Other SSL types/advance features are not supported with AnyConnect license. Clientless SSL VPN (through browser), CSD, HostScan, etc. are not supported with AnyConnect Essential license. You would need to purchase the AnyConnect premium license for that.
Hope that answers your question.
