Limit VPN Client to ASA from single site
Aug 12th, 2010
Hi folks,
so I've got a customer (custA) who wants to allow users of a customer of theirs (custB) to connect to custA's network via an ASA using Cisco VPN clients. I'm trying to secure it as much as possible. Can I somehow limit VPN Client connections to the ASA of custA from custB using the public IP of custB site?
The ASA has other LAN 2 LAN VPN sites that connect to it.
A LAN 2 LAN is not the preferred option here, specified by custA.
I have split tunneling to limit what IP's custB will connect to.
Via an ACL I have defined what ports and IP they connect to.
RSA will be used but in a couple of months time.
XAUTH is configured and using local usernames and passwords.
The public IP of custB is 2.2.2.2 (example for reference)
thanks
Dave
d.hodgson Thu, 08/12/2010 - 17:47
Hi Marcin,
thanks for your suggestions but that's not really what I'm after.
I'd like to deploy for a remote access VPN client something similar to VPN Peers for LAN 2 LAN's, is that possible using the Remote VPN clients site public IP address?
thanks
Dave
Marcin Latosiewicz Thu, 08/12/2010 - 23:39
Dave,
I don't believe there is an option like this since you land on dynamic crypto map most likely.
You would need to make a group-to-IP correlation at some point...
Sorry nothing rings a bell.
If it's only their headquarters that you would like to allow why not use L2L tunnel rather then remote access?
Seems like it's what you want anyway ;-)
Marcin
d.hodgson Thu, 08/19/2010 - 07:53
No worries. I thought it was worth asking the question.
Posted from my mobile device.
