ASA 8.3 and smart tunnel vsphere client
Aug 12th, 2010
Hi all,
i`ve setup smart tunnel with different applications. (mstsc.exe, putty.exe). This works fine. I`ve now tried to add the vSphere client appliaction (VpxClient.exe). But i don`t get it working.
My question now: Has somebody get it working or is this a vmware problem?
Paul Carco Sun, 08/15/2010 - 08:45
I attempted a Smart Tunnel for the VMware View-4 Client (PCOIP) and discovered that it uses both TCP and UDP - so it was not going to work since Smart Tunnels only work for Winsock 2 TCP based app's.   I am not certain but you may be running into the same issue.
Best regards,
Paul
bhhanson Thu, 07/26/2012 - 12:17
you can force the VMware View client to use RDP protocol and not PCoIP.
but i'm checking with Cisco as there is a VMware document floating about that is stating that the ASA SSL VPN can be setup using Smart Tunnel to support remote users.
Hoping we can get back to PCoIP and not stuck with RDP.
bhhanson Thu, 07/26/2012 - 12:23
me again.. found anoter reference that might help:
Clientless SSL VPN Core Rewriter
The ASA 8.3 clientless SSL VPN core rewriter supports the following applications:
Microsoft SharePoint 2003 and 2007
Microsoft Outlook Web Access 2003 and 2007
Citrix XenApp Version 4 and Version 5
Domino Web Access (DWA) 8.5 (We do not support DWA 8.5.1 and later.)
VMware View 4
