Wireless Novice
Hi Guys
I have a wireless client that is running Fedora that loses connectivity to the AP every 15 minutes when it is inside the bulding. When you associate the client with a different AP this issue does not happen. There are 2 two other wireless clients and they are working fine.
Could u guys please help
Thanks and regards
crazyguitarest Thu, 08/12/2010 - 07:46
Tell us a little bit more about your setup though. I'm personally wondering:
1. Is this an LWAPP or autonomous environment (do you have a WLC)?
2. What model are the APs?
3. What verson of code are you running?
4. Are the other clients also Linux?
I think the first thing I would try is to reboot the AP that's giving you trouble and then I would run some debugs of the client on the AP, which we can give you when we know what type of network you have.
Trending Topics - Security & Network
