problem starting Click-To-Call 8 on Windows 7
borutlape
I installed the latest Click To Call version 8-0-2540. My operating system is Windows 7 Pro 32 bit.
On startup I get Microsoft .NET Framework error :
The detailed log is here:
See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
System.ArgumentNullException: Value cannot be null.
Parameter name: value
   at System.String.IndexOf(String value, Int32 startIndex, Int32 count, StringComparison comparisonType)
   at Cisco.ClickToCall.ClickToCall.PreferencesForm.linkMoreOrLess_LinkClicked(Object sender, LinkLabelLinkClickedEventArgs e)
   at Cisco.ClickToCall.ClickToCall.PreferencesForm.LoadSettings()
   at Cisco.ClickToCall.ClickToCall.PreferencesForm.PreferencesForm_Load(Object sender, EventArgs e)
   at System.Windows.Forms.Form.OnLoad(EventArgs e)
   at System.Windows.Forms.Form.OnCreateControl()
   at System.Windows.Forms.Control.CreateControl(Boolean fIgnoreVisible)
   at System.Windows.Forms.Control.CreateControl()
   at System.Windows.Forms.Control.WmShowWindow(Message& m)
   at System.Windows.Forms.Control.WndProc(Message& m)
   at System.Windows.Forms.ScrollableControl.WndProc(Message& m)
   at System.Windows.Forms.ContainerControl.WndProc(Message& m)
   at System.Windows.Forms.Form.WmShowWindow(Message& m)
   at System.Windows.Forms.Form.WndProc(Message& m)
   at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
   at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
   at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Loaded Assemblies **************
mscorlib
    Assembly Version: 2.0.0.0
    Win32 Version: 2.0.50727.4927 (NetFXspW7.050727-4900)
    CodeBase: file:///C:/Windows/Microsoft.NET/Framework/v2.0.50727/mscorlib.dll
clicktocall
    Assembly Version: 8.0.2540.0
    Win32 Version: 8.0.2540.0
    CodeBase: file:///C:/Program%20Files/Cisco%20Systems/Click%20to%20Call/main/exe/clicktocall.exe
    CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Windows.Forms/2.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System
    CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll
System.Drawing
    CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Drawing/2.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
log4net
    Assembly Version: 1.2.10.0
    Win32 Version: 1.2.10.0
    CodeBase: file:///C:/Program%20Files/Cisco%20Systems/Click%20to%20Call/main/exe/log4net.DLL
Cisco.ClickToCall.Common.i18n
    Assembly Version: 0.0.0.0
    Win32 Version: 0.0.0.0
    CodeBase: file:///C:/Program%20Files/Cisco%20Systems/Click%20to%20Call/main/exe/Cisco.ClickToCall.Common.i18n.DLL
System.Configuration
    CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Configuration/2.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
System.Xml
    CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Xml/2.0.0.0__b77a5c561934e089/System.Xml.dll
clicktocall.resources
    CodeBase: file:///C:/Program%20Files/Cisco%20Systems/Click%20to%20Call/main/exe/en/clicktocall.resources.DLL
Cisco.ClickToCall.Common.Core
    CodeBase: file:///C:/Windows/assembly/GAC_MSIL/Cisco.ClickToCall.Common.Core/0.0.0.0__61541c5ee3826d68/Cisco.ClickToCall.Common.Core.dll
Cisco.ClickToCall.Controls.NotifyWindow
    CodeBase: file:///C:/Program%20Files/Cisco%20Systems/Click%20to%20Call/main/exe/Cisco.ClickToCall.Controls.NotifyWindow.DLL
System.Security
    Win32 Version: 2.0.50727.4951 (win7RTMGDR.050727-4900)
    CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Security/2.0.0.0__b03f5f7f11d50a3a/System.Security.dll
3yxpgtjf
wlm6kdaq
System.Data
    CodeBase: file:///C:/Windows/assembly/GAC_32/System.Data/2.0.0.0__b77a5c561934e089/System.Data.dll
Cisco.ClickToCall.Controls.LoadingCircle
    CodeBase: file:///C:/Program%20Files/Cisco%20Systems/Click%20to%20Call/main/exe/Cisco.ClickToCall.Controls.LoadingCircle.DLL
Cisco.ClickToCall.Common.WebDialer
    CodeBase: file:///C:/Program%20Files/Cisco%20Systems/Click%20to%20Call/main/exe/Cisco.ClickToCall.Common.WebDialer.DLL
************** JIT Debugging **************
To enable just-in-time (JIT) debugging, the .config file for this
application or computer (machine.config) must have the
jitDebugging value set in the system.windows.forms section.
The application must also be compiled with debugging
enabled.
For example:
<configuration>
    <system.windows.forms jitDebugging="true" />
</configuration>
When JIT debugging is enabled, any unhandled exception
will be sent to the JIT debugger registered on the computer
rather than be handled by this dialog box.
m12master
I had the same problem. And I use workaround.
In my case it helps if I change regional settings to US English, do installation and settings. When starting application next time error still aprears, but you can ignore it and ClickToCall is working anyway.
In my case you also don't see settings when trying to edit them and I have my usual regional settings.
matjaž
10 Replies 10
I have exactly the same problem on Windows XP SP3 32-bit.
amitev
Same problem - W7 x64 Office 2010
what file you was using for this installation?
regards,
Trad
Hi Trad,
The problem I believe was in the installation of my PC, or some problematic SW. I tested it on three other PCs without a problem.
BR
Alex
Hi Trad,
the file is: ClickToCallK9.exe.
aharon-n
Hi All
I saw this problem in several clients.
did some one got an answer from Cisco TAC?
I opened a case but didn't get a real answer yet.
m12master
matjaž
Thanx, it finally works!
Before you switch back to the original regional settings, make sure you have made all the configuration settings because the configuration windows will be blank after the revert...
Regards, Borut
Thank you so very much matjaz! I had the same problem with local Finnish settings as region, but that helped.
Is that really so, that Cisco doesn´t care about customers outside "US English" region...
Hi all
this problem is solved with an ES version of click to call.
you probably can't get it from the site but you can open a TAC and ask for it.
that is what I did.
