LMS 3 SNMP authentication using different communities
Answered Question
Aug 12th, 2010
Is it possible to use different community strings for the SNMP set/polling and traps in Ciscoworks.
Can't find this in the documentation or the web.
So the config on the network device would look something like this:
! SNMP communities
snmp-server community SNMPREAD RO    ! Read-Only community
snmp-server community SNMPWRITE RW    ! Read-Write communicy
! SNMP traps
snmp-server host 1.1.1.1 version 2c SNMPTRAPS                   ! SNMP trap
In LMS I can only find to configure the port timeout and read/write community of a device.
Thanks for the assistance in advance
Correct Answer by Joe Clarke about 6 years 9 months ago
LMS doesn't care about the trap community string (you can configure whatever value you want on the device).  However, you can certainly configure different read-only and read-write strings.  This is done under Common Services > Device and Credentials > Device Management.  Click the Edit Credentials button, then fill in the appropriate values for each string.
Overall Rating: 5 (1 ratings)
Correct Answer
Joe Clarke Sat, 08/14/2010 - 12:40
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
orsonjoon Sun, 08/15/2010 - 22:44
Allright Joe just what I needed to kno
w, many thanks again....
