getting error in phase 1 of vpn tunnel
Aug 12th, 2010
i am trying to establish a vpn tunnel between cisco 3030 and fortigate firewall.
but in phase 1 itself it throws a debug error
8635,08/12/2010,11:44:10.900,SEV=8,IKEDBG/79,RPT=254,Proposal # 1  Transform # 1  Type ISAKMP  Id IKEParsing received transform:  Phase 1 failure against global IKE proposal # 1:  Mismatched attr types for class Auth Method:    Rcv'd: Preshared Key    Cfg'd: XAUTH with Preshared Key (Initiator authenticated)
in fact what exactly it means and how we can resolve this issue..
Jennifer Halim Thu, 08/12/2010 - 04:37
  • Cisco Employee,
That means that there is no matching proposal (IKE/phase1) that matches between the Fortigate and the Cisco VPN Concentrator.
You would need to check out what has been configured for Fortigate (phase 1 proporsal) and match it on the VPN concentrator or vice versa.
prasanthlal Thu, 08/12/2010 - 05:16
in concentrator configuration is:
connection type:bi-directional
peer:next peer ip
digital certificate: using pre shared key
certificate transmission: Identity certificate only
authentication :esp/sha/hmac-160
encryption:3des-168
ike proposal:ike-3des-shafilter:none
bandwidth policy :none
routing n:none
local lan networklist:
remote lan network list:
and fortigate configuration is
authentication methodpreshared keyp1   proposalencyption3desauthentication   methodsha1dh   group2key   life86400xauthdisablemodemainpeer optionaccept any peerphase   2 cnfigarationencyption3desauthentication   methodsha1
key   life
both configuration is almost same..
seconds
28800
Jennifer Halim Thu, 08/12/2010 - 05:26
  • Cisco Employee,
To check the exact IKE policy, please go to:
Configuration | Tunneling and Security | IPSec | IKE Proposals: then choose "IKE-3DES-SHA" and modify.
Please check if all the algorithm matches (including the group).
