CUMA User activation
Aug 12th, 2010
I have a problem with an CUMA Server.
If I want to import a user I get the following error:
'Internal server error. Please check the Cisco Admin Server logs or contact Cisco Customer Support'
If I press Test config at the configuration website it tells me that it works proberly. The  user have read only rights in the AD.
The cuma.log is attached.
Achim
astrohmeier Thu, 08/12/2010 - 22:37
Hi Mady,
if you mean with testing to press the test config button in the Active Directory configuration page it tells me that the configuration is successful.
thanks Achim
htluo Thu, 08/12/2010 - 22:51
oz-bpv.rhf:389 [Root exception is java.net.UnknownHostException: oz-bpv.rhf]
It looks like CUMA server was not able to resolve oz-bpv.rhf to an IP address.
Michael
http://htluo.blogspot.com
astrohmeier Fri, 08/13/2010 - 00:23
I found the problem. There where no DNS Servers configured.
After entering the DNS it works.
Is it normal that I can import users only from AD and not frum CUCM?
thanks Achim
mightyking Wed, 10/20/2010 - 16:42
Where did you configure the DNS? Is it in CUMA server or in the DNS server? I can access the sever admin page using the FQDN and the IP Address. I don't think that I have DNS problem but the engine doesn't want to start. Do you have any idea what am I missing?
MK
