DNS Configuration
Aug 12th, 2010
I've set up a cisco 877 on a home network. I had problems getting internet access from the network initially. After playing about with it, i managed to get it working.
However, there is one slight problem. The guy's whose house I installed it in has a CCTV system that can be viewed from the internet via the url http;//chitchens.dyndns.tv:88 . This resolves to the public internet address of the router. I have set up PAT to translate all tcp 88 traffic over to the CCTV unit that sits on the LAN. When the guy connects to his CCTV url externally it works fine. However, when he tries to connect to the URL from his own network then the connection fails.
I suspect it's routing or DNS related. I am not sure if I have the DNS settings right. How should I be setting DNS for the router and the local DHCP clients?
The guys DSL connection DNS is 213.23.3.100 and 213.23.6.100, the CCTV is connected to 192.168.1.72
Here's the config:
Building configuration...
Current configuration : 16428 bytes
version 12.4
no service pad
service password-encryption
service sequence-numbers
hostname ch-home-rt
boot-start-marker
boot-end-marker
logging buffered 51200 warnings
enable secret 5 $1$PFSZ$V4gWvmoldeAtPDTDaaruy1
aaa new-model
aaa authentication login default local
aaa authentication login ciscocp_vpn_xauth_ml_1 local
aaa authentication login ciscocp_vpn_xauth_ml_2 local
aaa authentication login ciscocp_vpn_xauth_ml_3 local
aaa authentication login ciscocp_vpn_xauth_ml_4 local
aaa authentication login ciscocp_vpn_xauth_ml_5 local
aaa authorization exec default local
aaa authorization network ciscocp_vpn_group_ml_1 local
aaa authorization network ciscocp_vpn_group_ml_2 local
aaa authorization network ciscocp_vpn_group_ml_3 local
aaa authorization network ciscocp_vpn_group_ml_4 local
aaa authorization network ciscocp_vpn_group_ml_5 local
aaa session-id common
crypto pki trustpoint TP-self-signed-4221835501
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-4221835501
revocation-check none
rsakeypair TP-self-signed-4221835501
crypto pki certificate chain TP-self-signed-4221835501
certificate self-signed 01
  30820251 308201BA A0030201 02020101 300D0609 2A864886 F70D0101 04050030
  31312F30 2D060355 04031326 494F532D 53656C66 2D536967 6E65642D 43657274
  69666963 6174652D 34323231 38333535 3031301E 170D3032 30333031 30383538
  34385A17 0D323030 31303130 30303030 305A3031 312F302D 06035504 03132649
  4F532D53 656C662D 5369676E 65642D43 65727469 66696361 74652D34 32323138
  33353530 3130819F 300D0609 2A864886 F70D0101 01050003 818D0030 81890281
  8100A44F A3F502A7 22F209B2 6EF1E02A FBB59EA8 47945D0F 141B9621 7DA10016
  0A17E049 529912DC 5BC115FB 7820252C E06CB2A1 7A6C0419 650EFCB5 A08AB45D
  1BA3C0A0 FB388B49 C1ECEB8D A693157C E8952396 C5A79711 4C10958E B3E4429B
  C21A374F CD694218 8DFE483F 942152C0 C6A4FACF 077D2B71 F3D1585D 45EB8990
  4FE70203 010001A3 79307730 0F060355 1D130101 FF040530 030101FF 30240603
  551D1104 1D301B82 1963682D 686F6D65 2D72742E 796F7572 646F6D61 696E2E63
  6F6D301F 0603551D 23041830 16801490 51D25792 E93DAE59 CEEE452C A2809D27
  C5846230 1D060355 1D0E0416 04149051 D25792E9 3DAE59CE EE452CA2 809D27C5
  8462300D 06092A86 4886F70D 01010405 00038181 000377E8 961706C6 C08D2E75
  32F63A93 1596A93F DA148AAB 8CC1C8FF 7147EF64 37ABD302 EBE6826F 1B51AB60
  B3D64910 5F03B128 236B2210 B57885C2 B139F0BF 835A09FF BB5FE977 315D3649
  5E008DAC DCFF9F3C 9B4564AA A92C7F32 D9247C5D 6BD2637E 32041E63 370149AC
  06E975FA 087A6ECB 3F41F3B8 DA563401 75010A37 BD
   quit
dot11 syslog
dot11 ssid Langden
   vlan 1
   authentication open
   authentication key-management wpa
   mbssid guest-mode
   wpa-psk ascii 7 12310007415B5F057C73777E61
no ip source-route
ip cef
no ip dhcp use vrf connected
ip dhcp excluded-address 10.10.10.1
ip dhcp excluded-address 192.168.1.1 192.168.1.49
ip dhcp excluded-address 192.168.1.151 192.168.1.254
ip dhcp pool ccp-pool
   import all
   network 10.10.10.0 255.255.255.248
   default-router 10.10.10.1
   lease 0 2
ip dhcp pool chLAN
   import all
   network 192.168.1.0 255.255.255.0
   default-router 192.168.1.1
   dns-server 212.23.3.100 212.23.6.100
ip port-map user-ctcp-ezvpnsvr port tcp 10000
ip port-map user-cctudp port udp 88
ip port-map user-ezvpn-remote port udp 10000
no ip bootp server
ip domain name yourdomain.com
ip name-server 212.23.3.100
ip name-server 212.23.6.100
username dnstech privilege 15 secret 5 $1$J1fd$33MY4zTzQ8UljyfvCjdIj0
username chrish privilege 15 secret 5 $1$3Oui$LZhMcqX/rNUPC3RlJeiHX0
crypto logging ezvpn
crypto isakmp policy 1
encr 3des
authentication pre-share
group 2
crypto isakmp client configuration address-pool local SDM_POOL_1
crypto isakmp client configuration group chrisremote
key Hep303
dns 212.23.3.100 212.23.6.100
pool SDM_POOL_1
netmask 255.255.255.0
crypto isakmp profile ciscocp-ike-profile-1
   match identity group chrisremote
   client authentication list ciscocp_vpn_xauth_ml_5
   isakmp authorization list ciscocp_vpn_group_ml_5
   client configuration address initiate
   client configuration address respond
   virtual-template 5
crypto ipsec transform-set ESP-3DES-SHA esp-3des esp-sha-hmac
crypto ipsec transform-set ESP-3DES-SHA1 esp-3des esp-sha-hmac
crypto ipsec transform-set ESP-3DES-SHA2 esp-3des esp-sha-hmac
crypto ipsec profile CiscoCP_Profile1
set transform-set ESP-3DES-SHA2
set isakmp-profile ciscocp-ike-profile-1
crypto ctcp port 10000
archive
log config
  hidekeys
class-map type inspect match-any SDM_SSLVPN
match access-group name SDM_SSLVPN0
class-map type inspect match-any SDM_HTTPS
match access-group name SDM_HTTPS
class-map type inspect match-any SDM_SSH
match access-group name SDM_SSH
class-map type inspect match-any SDM_SHELL
match access-group name SDM_SHELL
class-map type inspect match-any sdm-cls-access
match class-map SDM_HTTPS
match class-map SDM_SSH
match class-map SDM_SHELL
match protocol ssh
match protocol telnet
class-map type inspect match-any cctv
match protocol kerberos
match protocol user-cctudp
class-map type inspect match-any SDM_TELNET
match access-group name SDM_TELNET0
class-map type inspect match-any SDM_AH
match access-group name SDM_AH
class-map type inspect match-any ccp-skinny-inspect
match protocol skinny
class-map type inspect match-any ccp-cls-insp-traffic
match protocol cuseeme
match protocol dns
match protocol ftp
match protocol https
match protocol icmp
match protocol imap
match protocol pop3
match protocol netshow
match protocol shell
match protocol realmedia
match protocol rtsp
match protocol smtp extended
match protocol sql-net
match protocol streamworks
match protocol tftp
match protocol vdolive
match protocol tcp
match protocol udp
class-map type inspect match-all ccp-insp-traffic
match class-map ccp-cls-insp-traffic
class-map type inspect match-any SDM_EIGRP
match access-group name SDM_EIGRP0
class-map type inspect match-any remotesl
match protocol ssh
match class-map SDM_AH
match class-map SDM_EIGRP
match class-map SDM_TELNET
match class-map SDM_SSLVPN
class-map type inspect match-any SDM_IP
match access-group name SDM_IP
class-map type inspect match-any SDM_ESP
match access-group name SDM_ESP
class-map type inspect match-any SDM_EASY_VPN_REMOTE_TRAFFIC
match protocol isakmp
match protocol ipsec-msft
match class-map SDM_ESP
match protocol user-ezvpn-remote
class-map type inspect match-all SDM_EASY_VPN_REMOTE_PT
match class-map SDM_EASY_VPN_REMOTE_TRAFFIC
match access-group 102
class-map type inspect match-any SDM_EASY_VPN_SERVER_TRAFFIC
match protocol user-ctcp-ezvpnsvr
match protocol ssp
match protocol gdoi
class-map type inspect match-all SDM_EASY_VPN_SERVER_PT
match class-map SDM_EASY_VPN_SERVER_TRAFFIC
class-map type inspect match-any ccp-cls-icmp-access
match protocol icmp
match protocol tcp
match protocol udp
class-map type inspect match-any ccp-h225ras-inspect
match protocol h225ras
class-map type inspect match-any cctv-both
class-map type inspect match-all sdm-access
match class-map sdm-cls-access
match access-group 101
class-map type inspect match-all ccp-cls-ccp-permit-1
match class-map remotesl
match access-group name stevelatimer
class-map type inspect match-any ccp-h323-inspect
match protocol h323
class-map type inspect match-all ccp-invalid-src
match access-group 100
class-map type inspect match-all ccp-icmp-access
match class-map ccp-cls-icmp-access
class-map type inspect match-any ccp-sip-inspect
match protocol sip
class-map type inspect match-all ccp-protocol-http
match protocol http
policy-map type inspect ccp-permit-icmpreply
class type inspect ccp-icmp-access
  inspect
class class-default
  pass
policy-map type inspect ccp-inspect
class type inspect ccp-invalid-src
  drop log
class type inspect ccp-protocol-http
  inspect
class type inspect ccp-insp-traffic
  inspect
class type inspect ccp-h323-inspect
  inspect
class type inspect ccp-h225ras-inspect
  inspect
class class-default
class type inspect SDM_EASY_VPN_SERVER_PT
  pass
class type inspect cctv
  pass log
class type inspect sdm-access
  pass
class type inspect ccp-cls-ccp-permit-1
  pass
class class-default
policy-map type inspect ccp-policy-cctv-both
class type inspect cctv-both
  inspect
class class-default
policy-map type inspect sdm-permit-ip
class type inspect SDM_IP
  pass
class class-default
  drop log
zone security out-zone
zone security in-zone
zone security ezvpn-zone
zone-pair security ccp-zp-self-out source self destination out-zone
service-policy type inspect ccp-permit-icmpreply
zone-pair security ccp-zp-in-out source in-zone destination out-zone
service-policy type inspect ccp-inspect
zone-pair security ccp-zp-out-self source out-zone destination self
zone-pair security sdm-zp-in-ezvpn1 source in-zone destination ezvpn-zone
service-policy type inspect sdm-permit-ip
zone-pair security sdm-zp-out-ezpn1 source out-zone destination ezvpn-zone
zone-pair security sdm-zp-ezvpn-out1 source ezvpn-zone destination out-zone
zone-pair security sdm-zp-ezvpn-in1 source ezvpn-zone destination in-zone
zone-pair security sdm-zp-out-zone-in-zone source out-zone destination in-zone
service-policy type inspect ccp-policy-cctv-both
bridge irb
interface ATM0
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
no atm ilmi-keepalive
dsl operating-mode auto
interface ATM0.1 point-to-point
description $ES_WAN$
no ip redirects
no ip unreachables
no ip proxy-arp
pvc 0/38
  encapsulation aal5mux ppp dialer
  dialer pool-member 1
interface FastEthernet0
interface FastEthernet1
interface FastEthernet2
interface FastEthernet3
interface Virtual-Template5 type tunnel
ip unnumbered BVI1
ip nat inside
ip virtual-reassembly
tunnel mode ipsec ipv4
tunnel protection ipsec profile CiscoCP_Profile1
interface Dot11Radio0
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
encryption vlan 1 mode ciphers aes-ccm tkip
broadcast-key vlan 1 change 30
ssid Langden
mbssid
speed basic-1.0 basic-2.0 basic-5.5 6.0 9.0 basic-11.0 12.0 18.0 24.0 36.0 48.0 54.0
station-role root
interface Dot11Radio0.1
encapsulation dot1Q 1 native
no cdp enable
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 spanning-disabled
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
interface Vlan1
no ip address
bridge-group 1
interface Vlan2
no ip address
bridge-group 2
interface Dialer0
description $FW_OUTSIDE$
ip address negotiated
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat outside
zone-member security out-zone
encapsulation ppp
dialer pool 1
dialer-group 1
no cdp enable
ppp authentication chap pap callin
ppp chap hostname [email protected]
ppp chap password 7 1511133C0A0D332C3F
ppp pap sent-username [email protected] password 7 02051C6B052117295B
interface BVI1
description $FW_INSIDE$
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat inside
zone-member security in-zone
interface BVI2
no ip address
ip local pool SDM_POOL_1 192.168.1.220 192.168.1.229
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 Dialer0 2
ip http server
ip http access-class 23
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip nat inside source list 1 interface Dialer0 overload
ip nat inside source static tcp 192.168.1.72 88 interface Dialer0 88
ip nat inside source static udp 192.168.1.72 88 interface Dialer0 88
ip access-list extended SDM_AH
remark CCP_ACL Category=1
permit ahp any any
ip access-list extended SDM_EIGRP
remark CCP_ACL Category=0
permit eigrp any any
ip access-list extended SDM_EIGRP0
ip access-list extended SDM_ESP
permit esp any any
ip access-list extended SDM_GRE
permit gre any any
ip access-list extended SDM_GRE0
permit gre any any
ip access-list extended SDM_HTTP
permit tcp any any eq telnet
ip access-list extended SDM_HTTP0
ip access-list extended SDM_HTTPS
permit tcp any any eq 443
ip access-list extended SDM_IGMP
permit ip any any
ip access-list extended SDM_IP
permit ip any any
ip access-list extended SDM_IPINIP
permit ipinip any any
ip access-list extended SDM_IPINIP0
ip access-list extended SDM_NOS
permit nos any any
ip access-list extended SDM_OSPF
permit ospf any any
ip access-list extended SDM_PCP
permit pcp any any
ip access-list extended SDM_PCP0
permit pcp any any
ip access-list extended SDM_PIM
ip access-list extended SDM_PIM0
ip access-list extended SDM_SHELL
permit tcp any any eq cmd
ip access-list extended SDM_SSH
permit tcp any any eq 22
ip access-list extended SDM_SSLVPN
permit tcp any any eq 4443
ip access-list extended SDM_SSLVPN0
ip access-list extended SDM_TELNET
permit tcp any any
ip access-list extended SDM_TELNET0
permit tcp any any
ip access-list extended stevelatimer
remark CCP_ACL Category=128
permit ip host 212.159.12.62 any
access-list 1 remark CCP_ACL Category=2
access-list 1 permit 192.168.1.0 0.0.0.255
access-list 23 permit 192.168.0.0 0.0.255.255
access-list 23 permit 10.10.10.0 0.0.0.255
access-list 100 remark CCP_ACL Category=128
access-list 100 permit ip host 255.255.255.255 any
access-list 100 permit ip 127.0.0.0 0.255.255.255 any
access-list 101 remark CCP_ACL Category=128
access-list 101 permit ip host 212.159.12.62 any
access-list 102 remark CCP_ACL Category=128
access-list 102 permit ip host 82.69.105.59 any
dialer-list 1 protocol ip permit
control-plane
bridge 1 protocol ieee
bridge 1 route ip
bridge 2 protocol ieee
bridge 2 route ip
banner exec ^C
% Password expiration warning.
Cisco Configuration Professional (Cisco CP) is installed on this device
and it provides the default username "cisco" for  one-time use. If you have
already used the username "cisco" to login to the router and your IOS image
supports the "one-time" user option, then this username has already expired.
You will not be able to login to the router with this username after you exit
this session.
It is strongly suggested that you create a new username with a privilege level
of 15 using the following command.
username <myuser> privilege 15 secret 0 <mypassword>
Replace <myuser> and <mypassword> with the username and password you
want to use.
^C
banner login ^C
The Device is the personal property of Chris Hitchens.
This is a private network, unauthorised access to this device
and network is strictly forbidden
-----------------------------------------------------------------------^C
line con 0
exec-timeout 0 0
logging synchronous
no modem enable
line aux 0
line vty 0 4
access-class 23 in
exec-timeout 0 0
logging synchronous
transport input telnet ssh
scheduler max-task-time 5000
end
Any help or pointers are greatly appreciated.
Mike
