DMM-DMP communication ports
Answered Question
Aug 12th, 2010
Hi all,
I have a request from our client to restrict the access between the DMM and the DMPS only to the usable ports.
So i ended up to the following ports: 20,21,80,8443,443,7777,6666 all TCP ports initiating connection from the DMM to the DMPS.
I have applied the access list but it seems that i cannt push/change content to the DMPs but on the contrary, i can perform tasks on them.
Am i missing any ports here or is it using dynamic ports?
Thanking you all
Correct Answer by Tomas De Leon about 6 years 6 months ago
Panay,
There is actually more ports that you need to
be aware of.  Enclosed is a more detailed
list.
Cheers!
T.
Correct Answer by Charles Little about 6 years 6 months ago
Attached is a PPT preso that lists all the ports required for DMS. I hope this is helpful.
Cheers
C.O. Little
Overall Rating: 5 (2 ratings)
Charles Little Thu, 08/12/2010 - 09:05
Tom
Excellant Doc. It would be great to get this document posted up on the ciscoet.com site.
Cheers
panayiotiscy Mon, 08/16/2010 - 02:44
Hi all,
I'm resuming this conversation because i'm not able to access the DMP by gui after applying the access list
So, i have permitted the communication to be:
From Admin Pc to DMPs: ports 80 and 443.
This enables me to navigate to dmp,accept the ssl certificate and login to the DMP.
Then,all i get is a blank screen on the web browser (both ie and mozilla).
Do i need to permit anything else apart from these 2 ports?
Thank you all.
Tomas De Leon Mon, 08/16/2010 - 13:44
Panay,
Remember the TCP traffic is 2-way.
Ports 80 & 443 are correct if you apply the access-list as
in & out.
The Admin device is going to use the DEST port as 80 or 443
with a SRC of something like 58xxx.   The DMP will respond
with a DEST of 58xxx and a SRC of 80 or 443.
It sounds like you are allowing 80 & 443 out but not back in...
You be able to turn on debugging on the Router for access violations
and you see what ports are failing the access list.
I hope this helps..
T.
panayiotiscy Wed, 08/18/2010 - 23:27
Hi Tomas,
IT was a flash player issue!
Flash player was not installed on that computer.
The access list is testes (as stated before) and is working ok!
Thanking you
Related Content
