Configure Cisco Access Point by SNMP
Aug 12th, 2010
I'm trying to configure my WLAN access point Aironet 1252 (AIR,RM1252A-E-K9; IOS version 12.4(10b)JA) by SNMP.
The community string for read/ write access is set and the SNMP configuration is working. For example I'm able to restart the device.
I like to change the WPA Pre-shared Key but I cannot find a fitting OID. I searched any MIB's for the access point and try to find something by doing an snmp walk.
Can anyone help me?
Thanks!
IT Eissmann Thu, 08/12/2010 - 07:20
thank's for your support.
I discovered the OID fitting to the VLAN and SSID (enterprises.9.9.413.1.1.1.1.7.13.69.71.65.87.76.65.78.45.71.85.69.83.84).
But if I try to set some value I get the following error message from snmpset (net-snmp, linux):
Error in packet.
Reason: commitFailed
Failed object: SNMPv2-SMI::enterprises.9.9.413.1.1.1.1.7.13.69.71.65.87.76.65.78.45.71.85.69.83.84
Have you an idea why this doesn't work?
By the way: I'm using Multi-SSID's and VLAN's.
Kind regards
Trending Topics - Security & Network
