4402 controller high LAN utilization(600 Mbps)
Aug 12th, 2010
Hi everybody,
I'm trying to configure Cisco 4402 series wireless lan controller on a proof of concept lab, but it's generating extremely high LAN utilization (around 600-700 Mbps) on its connected port to backbone switch. We are using GLC-T on 4402's port 0 for local connectivity. This traffic is starting even we do not use any access points in wireless network.
I configured controller 2 times after resetting to factory default, but the result is the same.
Best Regards
Ozan Oguz
CCIE#22559
Stephen Rodriguez Thu, 08/12/2010 - 08:41
  • Purple, 4500 points or more
Ozan,
     What is the config on the connected switchports?  In genearl you want to prune the non-used VLAN from the trunk.
Ozan Oguz Tue, 08/24/2010 - 05:39
problem has been solved by adding "switchport trunk allowed vlan x,y,z" command to the backbone switch.
OZan
George Stefanick Wed, 08/25/2010 - 16:25
  • Community Spotlight Award,
    Best Publication, October 2015
Ozan,
So why the high utilization then? I understand you didnt have the vlans added to the switch .. but what caused the massive traffic load?
Trending Topics - Security & Network
