08-12-2010 07:57 AM - edited 03-04-2019 09:23 AM
HI all,
We are planning to connect to a VPLS provider for our WAN Connectivity.
The provider is asking us to tag the traffic on the interface going to the VPLS.
We are planning using EIGRP, testing phases are running OK with the subinterface being tagged.
The question is, should I used tag or untagged for the VPLS connection. Consider your answer toward us moving to VoIP next year.
08-12-2010 08:50 AM
so tag it with a Vlan based subinterface as you have already done in tests
Having a tag provide a way to carry 802.1p CoS so it is better for future VoIP deployment.
Hope to help
Giuseppe
08-12-2010 09:45 AM
Hi Giuslar,
Thanks for your response. That give me a point to start.
