CiscoWorks HUM Poller Query/Clarification
Aug 12th, 2010
/* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-priority:99; mso-style-qformat:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman","serif";}
I have a query related to Pollers in HUM 1.2 :
In the HUM Poller Creation , we have an option to “poll all instances”. I am checking it because I want to poll all available instances on the device so that complete information about all devices is available for device statistics like Top N/Bottom N Utilization/Errors etc. .. on the HUM portal..
In the Poller Status, I see some errors and the failure status is “Permanent” and the reason is “No Such Instance - The specified instance is not available”. I don’t see any reason why this is happening, because HUM itself is polling the devices and fetching the instances available & it is throwing an error saying instance is not available. As per my understanding (Please correct me if I am wrong !),  It makes sense if the failure status is “Transient” which would mean that device is down/SNMP credentials are incorrect/SNMP request time out . However I see the Failure status is “Permanent”.
Could any of you please tell me why this is happening ?
Also please let me know how do we avoid “Permanent” Poller failures ?
Appreciate your help and support,
Thanks & Regards,
Naveen
Farrukh Haroon Thu, 08/19/2010 - 14:00
These are usually sub-interfaces or those not supported by HUM (can also be due to bugs). You should go ahread and remove polling from the error prone interfaces after confirming that they actually exist on the device.
The 'all instances' option is not suitable for most environments. You must chose the interfaces manually to perform adequate polling.
Farrukh
naveeku2 Fri, 08/20/2010 - 12:22
Hi Farrukh,
                    Thanks for your reply.Manually choosing the interfaces is a good option. But, it becomes very tedious and time consuming when the number of devices and their assosiated interfaces becomes very large. I was wondering is there's a way to automate this ., as in HUM should poll only those interfaces which are operationally up.
Naveen
Farrukh Haroon Mon, 08/23/2010 - 13:33
well you could try to shut down the un-used interfaces and then try to discover the device in HUM, I think this should help you.
Farrukh
Related Content
