How to configure rate limit in catalyst 2960
Aug 12th, 2010
/* Style Definitions */ table.MsoNormalTable {mso-style-name:"Tableau Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-priority:99; mso-style-qformat:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:11.0pt; font-family:"Calibri","sans-serif"; mso-ascii-font-family:Calibri; mso-ascii-theme-font:minor-latin; mso-fareast-font-family:"Times New Roman"; mso-fareast-theme-font:minor-fareast; mso-hansi-font-family:Calibri; mso-hansi-theme-font:minor-latin; mso-bidi-font-family:"Times New Roman"; mso-bidi-theme-font:minor-bidi;}
We have Catalyst 2960, we must limit the input output interfaces at a constant rate (eg 40Mb / s). rate-limit function is not currently supported, is what you intend to change the ios for the function is supported?
if not, how I can do to meet this need?
thank you for your reply
Giuseppe Larosa Thu, 08/12/2010 - 08:57
  • Hall of Fame,
    Founding Member
hello David,
by using QoS you can  limit outbound
see
http://www.cisco.com/en/US/docs/switches/lan/catalyst2960/software/release/12.2_53_se/configuration/guide/swqos.html#wp1253412
This example shows how to limit the bandwidth on a port to 80 percent:
Switch(config)# interface gigabitethernet0/1
Switch(config-if)# srr-queue bandwidth limit 80
I'm afraid nothing can be done for inbound
Hope to help
Giuseppe
