ASA intra-interface communication
Answered Question
Aug 12th, 2010
I have three interfaces configured, outside, inside and dhcp.  The IP for the inside is 10.10.220.101 and dhcp is 10.10.230.1, with same−security−traffic permit intra−interface configured but still not able to communicate between interfaces.  The error I receive from packet-tracer is (acl-drop) flow is denied by configured rule.
Correct Answer by Nagaraja Thanthry about 6 years 11 months ago
You are missing NAT statements between inside and LANDHP. Please configure
identity NAT between the interfaces:
static (inside,LANDHCP) 10.10.220.0 10.10.220.0 netmask 255.255.255.0
static (LANDHCP,inside) 10.10.230.0 10.10.230.0 netmask 255.255.255.0
This should allow communication between the inside and LANDHCP interfaces.
Hope this helps.
NT
Overall Rating: 5 (2 ratings)
Collin Clark Thu, 08/12/2010 - 08:47
  • Purple, 4500 points or more
The flow drop usually means a NAT is missing. You need NAT when you go from a lower security interface to a higher one. The same−security−traffic permit intra−interface command is used when two interfaces have the same security level. Here's a helpful link.
http://www.cisco.com/en/US/products/ps6120/products_configuration_example09186a00807fc191.shtml#Same
Hope it helps
Jitendriya Athavale Thu, 08/12/2010 - 10:21
  • Cisco Employee,
you will need same-security-traffic permit inter-interface
intra interface is used when the traffic is entering and exiting from the same interface
here you have 2 different interfaces so you will need inter interface which mean traffic between same security level but on different interfaces
also what code are you running and lastly paste the output of packet tracer if it still doesnt work
stephilewis Thu, 08/12/2010 - 11:05
Yes you are correct I did change from intra to inter, using 7.2.
stephilewis Thu, 08/12/2010 - 11:29
/* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:12.0pt; font-family:"Times New Roman"; mso-ascii-font-family:Cambria; mso-ascii-theme-font:minor-latin; mso-fareast-font-family:"Times New Roman"; mso-fareast-theme-font:minor-fareast; mso-hansi-font-family:Cambria; mso-hansi-theme-font:minor-latin;}
edge# packet-tracer input inside icmp 10.10.220.101 8 0 10.10.230.101 detailed
Phase: 1
Type: ACCESS-LIST
Subtype:
Result: ALLOW
Config:
Implicit Rule
Additional Information:
Forward Flow based lookup yields rule:
in  id=0x37f0288, priority=1, domain=permit, deny=false
        hits=2085041387, user_data=0x0, cs_id=0x0, l3_type=0x8
        src mac=0000.0000.0000, mask=0000.0000.0000
        dst mac=0000.0000.0000, mask=0000.0000.0000
Phase: 2
Type: FLOW-LOOKUP
Subtype:
Result: ALLOW
Config:
Found no matching flow, creating a new flow
Phase: 3
Type: ROUTE-LOOKUP
Subtype: input
Result: ALLOW
Config:
in   10.10.230.101   255.255.255.255 identity
Phase: 4
Type: ACCESS-LIST
Subtype:
Result: DROP
Config:
Implicit Rule
in  id=0x3802b20, priority=500, domain=permit, deny=true
        hits=1, user_data=0x6, cs_id=0x0, reverse, flags=0x0, protocol=0
        src ip=10.10.220.101, mask=255.255.255.255, port=0
        dst ip=0.0.0.0, mask=0.0.0.0, port=0
Result:
input-interface: inside
input-status: up
input-line-status: up
output-interface: NP Identity Ifc
output-status: up
output-line-status: up
Action: drop
Drop-reason: (acl-drop) Flow is denied by configured rule
Collin Clark Thu, 08/12/2010 - 11:34
Can you post the ACL and the access group?
stephilewis Thu, 08/12/2010 - 11:58
heres my running
edge(config-if)# show run
: Saved
ASA Version 7.2(3)
hostname edge
domain-name xxxxxx
enable password sh3Lt8bNBi5BmLfG encrypted
names
interface Vlan1
nameif inside
security-level 100
ip address 10.10.220.101 255.255.255.0
ospf cost 10
interface Vlan2
nameif outside
security-level 0
ip address xx.xx.xx.xx 255.255.255.240
ospf cost 10
interface Vlan4
nameif LANDHCP
security-level 100
ip address 10.10.230.1 255.255.255.0
interface Vlan22
description LAN Failover Interface
interface Ethernet0/0
switchport access vlan 2
interface Ethernet0/1
interface Ethernet0/2
interface Ethernet0/3
interface Ethernet0/4
interface Ethernet0/5
switchport access vlan 4
interface Ethernet0/6
switchport access vlan 3
interface Ethernet0/7
passwd 2KFQnbNIdI.2KYOU encrypted
ftp mode passive
dns server-group DefaultDNS
domain-name benetech.org
access-list outside_access_in extended permit tcp any host xx.xx.xx.xx
access-list outside_access_in extended permit gre any any
access-list outside_access_in extended permit tcp any interface outside eq smtp log debugging
access-list outside_access_in extended permit tcp any interface outside eq https
access-list outside_access_in extended permit tcp any interface outside eq pptp log warnings
access-list outside_access_in extended permit tcp any interface outside eq 99
access-list outside_access_in extended permit tcp any interface outside eq 722 log
access-list outside_access_in extended permit tcp any interface outside eq 822 log
access-list outside_access_in extended permit tcp any interface outside eq 922 log
access-list outside_access_in extended permit tcp any interface outside eq www inactive
access-list outside_access_in extended permit tcp any interface outside eq ftp
access-list outside_access_in extended permit tcp any interface outside eq ftp-data
access-list outside_access_in extended permit tcp any interface outside eq 622
access-list outside_access_in extended permit icmp any interface outside
access-list LAN_access_in extended permit ip any any
access-list inside_access_out extended deny tcp 10.10.220.128 255.255.255.128 any eq smtp log warnings
access-list inside_access_out extended deny udp any eq 4000 any log warnings
access-list inside_access_out extended permit ip any any
access-list WLAN extended permit ip any any
access-list WLAN_access_in extended permit ip any any
access-list WLAN_access_in extended permit udp any any
pager lines 24
logging enable
logging emblem
logging asdm-buffer-size 512
logging buffered informational
logging trap informational
logging asdm informational
logging mail informational
logging from-address [email protected]
logging recipient-address xxxx level errors
logging host inside 10.10.220.69 17/1470 format emblem
logging permit-hostdown
mtu inside 1500
mtu outside 1500
mtu LANDHCP 1500
no failover
failover lan unit primary
failover lan interface BFailover Vlan22
failover key *****
failover interface ip BFailover 172.1.1.1 255.255.255.0 standby 172.1.1.2
icmp unreachable rate-limit 1 burst-size 1
asdm image disk0:/asdm-523.bin
no asdm history enable
arp timeout 14400
global (inside) 1 interface
global (outside) 1 interface
nat (inside) 1 0.0.0.0 0.0.0.0
static (inside,outside) tcp interface 822 10.10.220.21 822 netmask 255.255.255.255
static (inside,outside) tcp interface 722 10.10.220.18 722 netmask 255.255.255.255
static (inside,outside) tcp interface 922 10.10.220.29 922 netmask 255.255.255.255
static (inside,outside) tcp interface www 10.10.220.19 www netmask 255.255.255.255
static (inside,outside) tcp xx.xx.xx.xx ftp-data 10.10.220.67 ftp-data netmask 255.255.255.255
static (inside,outside) tcp interface ftp 10.10.220.67 ftp netmask 255.255.255.255
static (inside,outside) tcp interface 622 10.10.220.21 622 netmask 255.255.255.255
static (inside,outside) tcp interface 99 10.10.220.24 99 netmask 255.255.255.255
static (inside,outside) xx.xx.xx.xx 10.10.220.4 netmask 255.255.255.255
static (inside,outside) xx.xx.xx.xx 10.10.220.23 netmask 255.255.255.255
access-group inside_access_out out interface inside
access-group outside_access_in in interface outside
route outside 0.0.0.0 0.0.0.0 xx.xx.xx.xx 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout uauth 0:05:00 absolute
http server enable
http 10.10.220.0 255.255.255.0 inside
http 192.168.1.0 255.255.255.0 inside
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart
crypto ca trustpoint newbroot
crl configure
telnet timeout 5
ssh timeout 5
ssh version 2
console timeout 0
dhcpd dns 10.10.220.23
dhcpd domain benetech.local
dhcpd auto_config outside
dhcpd option 3 ip 172.16.30.100
class-map inspection_default
match default-inspection-traffic
class-map pptp-port
match port tcp eq pptp
policy-map type inspect dns preset_dns_map
parameters
  message-length maximum 512
policy-map type inspect dns benetech_dns_map
description Remove 512 byte size restriction
parameters
  message-length maximum 1024
  no protocol-enforcement
policy-map global_policy
class inspection_default
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect rsh
  inspect rtsp
inspect sqlnet
  inspect skinny
  inspect sunrpc
  inspect xdmcp
  inspect sip
  inspect netbios
  inspect tftp
  inspect pptp
policy-map pptp_policy
class pptp-port
  inspect pptp
service-policy global_policy global
service-policy pptp_policy interface outside
ntp server xx.xx.xx.xx source outside
tftp-server inside 10.10.220.69 asa-5505-primary.conf
webvpn
csd image disk0:/securedesktop-asa-3.1.1.29-k9.pkg
csd enable
username scott password rj0sFMSN.wCXUz0C encrypted privilege 15
username ryan password esjVcPBkxKv5/kd4 encrypted privilege 15
smtp-server 10.10.220.50 10.10.220.12
privilege cmd level 3 mode exec command perfmon
privilege cmd level 3 mode exec command ping
privilege cmd level 3 mode exec command who
privilege cmd level 3 mode exec command logging
privilege cmd level 3 mode exec command failover
privilege show level 5 mode exec command running-config
privilege show level 3 mode exec command reload
privilege show level 3 mode exec command mode
privilege show level 3 mode exec command firewall
privilege show level 3 mode exec command interface
privilege show level 3 mode exec command clock
privilege show level 3 mode exec command dns-hosts
privilege show level 3 mode exec command access-list
privilege show level 3 mode exec command logging
privilege show level 3 mode exec command ip
privilege show level 3 mode exec command failover
privilege show level 3 mode exec command asdm
privilege show level 3 mode exec command arp
privilege show level 3 mode exec command route
privilege show level 3 mode exec command ospf
privilege show level 3 mode exec command aaa-server
privilege show level 3 mode exec command crypto
privilege show level 3 mode exec command vpn-sessiondb
privilege show level 3 mode exec command ssh
privilege show level 3 mode exec command dhcpd
privilege show level 3 mode exec command blocks
privilege show level 3 mode exec command uauth
privilege show level 3 mode configure command interface
privilege show level 3 mode configure command clock
privilege show level 3 mode configure command access-list
privilege show level 3 mode configure command logging
privilege show level 3 mode configure command ip
privilege show level 3 mode configure command failover
privilege show level 5 mode configure command asdm
privilege show level 3 mode configure command arp
privilege show level 3 mode configure command route
privilege show level 3 mode configure command aaa-server
privilege show level 3 mode configure command crypto
privilege show level 3 mode configure command ssh
privilege show level 3 mode configure command dhcpd
privilege show level 5 mode configure command privilege
privilege clear level 3 mode exec command dns-hosts
privilege clear level 3 mode exec command logging
privilege clear level 3 mode exec command arp
privilege clear level 3 mode exec command aaa-server
privilege clear level 3 mode exec command crypto
privilege cmd level 3 mode configure command failover
privilege clear level 3 mode configure command logging
privilege clear level 3 mode configure command arp
privilege clear level 3 mode configure command crypto
privilege clear level 3 mode configure command aaa-server
prompt hostname context
Cryptochecksum:08ce842567f3902a3dd22fe93b0ddc0d
: end
edge(config-if)#
Collin Clark Thu, 08/12/2010 - 14:13
Can you create an ACL with permit ip any any and apply it to the dhcp interface? I don't remember if an ACL is needed between same security interfaces. This will just be a quick test.
access-list dhcp_access extended permit ip any any
access-group dhcp_access in interface LANDHCP
Collin Clark Thu, 08/12/2010 - 14:28
You can name the access list anything you like, I just named it dhcp_access.
stephilewis Thu, 08/12/2010 - 14:32
ok i completed the task i am permitting all ip traffic both ways without success, oddly enough from the workstation i cannot ping the gateway which is the landhcp interface.  from the console i can ping the landhcp but not past this.
Collin Clark Thu, 08/12/2010 - 14:34
Can you run the packet trace with the ACL applied and post the results?
stephilewis Thu, 08/12/2010 - 14:46
I am heading out for the day but will run one tomorrow and post
Thank you,
stephilewis Fri, 08/13/2010 - 11:06
edge(config)# packet-tracer input inside icmp 10.10.220.101 8 0 10.10.200.105 $
Phase: 1
Type: FLOW-LOOKUP
Subtype:
Result: ALLOW
Config:
Phase: 2
Type: ROUTE-LOOKUP
Subtype: input
Result: ALLOW
Config:
in   10.10.200.0     255.255.255.0   LANDHCP
Phase: 3
Type: ACCESS-LIST
Subtype:
Result: DROP
Config:
Implicit Rule
        hits=6, user_data=0x6, cs_id=0x0, reverse, flags=0x0, protocol=0
Result:
input-status: up
output-interface: LANDHCP
output-status: up
Action: drop
edge(config)#
Result:
input-status: up
output-status: up
Action: drop
edge(config)# packet-tracer input inside icmp 10.10.220.101 8 0 10.10.200.1 de$
Phase: 1
Type: FLOW-LOOKUP
Subtype:
Result: ALLOW
Config:
Phase: 2
Type: ROUTE-LOOKUP
Subtype: input
Result: ALLOW
Config:
in   10.10.200.1     255.255.255.255 identity
Phase: 3
Type: ACCESS-LIST
Subtype:
Result: DROP
Config:
Implicit Rule
        hits=7, user_data=0x6, cs_id=0x0, reverse, flags=0x0, protocol=0
Result:
input-status: up
output-status: up
Action: drop
edge(config)# packet-tracer input inside icmp 10.10.200.1 8 0 10.10.200.105 de$
Phase: 1
Type: FLOW-LOOKUP
Subtype:
Result: ALLOW
Config:
Phase: 2
Type: ROUTE-LOOKUP
Subtype: input
Result: ALLOW
Config:
Phase: 3
Type: ACCESS-LIST
Subtype:
Result: ALLOW
Config:
Implicit Rule
in  id=0x4273218, priority=2, domain=permit, deny=false
        hits=0, user_data=0x0, cs_id=0x0, flags=0x3000, protocol=0
        src ip=0.0.0.0, mask=0.0.0.0, port=0
Phase: 4
Type: IP-OPTIONS
Subtype:
Result: ALLOW
Config:
in  id=0x37f35b0, priority=0, domain=permit-ip-option, deny=true
        hits=37898762, user_data=0x0, cs_id=0x0, reverse, flags=0x0, protocol=0
Phase: 5
Type: INSPECT
Subtype: np-inspect
Result: ALLOW
Config:
in  id=0x37f5180, priority=66, domain=inspect-icmp-error, deny=false
        hits=196678, user_data=0x37f50b0, cs_id=0x0, use_real_addr, flags=0x0, protocol=1
Phase: 6
Type: NAT
Subtype:
Result: DROP
Config:
  match ip inside any LANDHCP any
    dynamic translation to pool 1 (No matching global)
    translate_hits = 1, untranslate_hits = 0
in  id=0x42cb620, priority=1, domain=nat, deny=false
        hits=0, user_data=0x426a0e8, cs_id=0x0, flags=0x0, protocol=0
Result:
input-status: up
output-status: up
Action: drop
Correct Answer
Nagaraja Thanthry Fri, 08/13/2010 - 12:08
  • Cisco Employee,
Hope this helps.
NT
stephilewis Fri, 08/13/2010 - 12:32
I am still getting the following, also I cannot ping from a node on the 10.10.220.0 network to 10.10.200.1 which is the interface on the asa.
Phase: 1
Type: FLOW-LOOKUP
Subtype:
Result: ALLOW
Config:
Phase: 2
Type: UN-NAT
Subtype: static
Result: ALLOW
Config:
static (LANDHCP,inside) 10.10.200.0 10.10.200.0 netmask 255.255.255.0
  match ip LANDHCP 10.10.200.0 255.255.255.0 inside any
    static translation to 10.10.200.0
    translate_hits = 3, untranslate_hits = 34
NAT divert to egress interface LANDHCP
Untranslate 10.10.200.0/0 to 10.10.200.0/0 using netmask 255.255.255.0
Phase: 3
Type: ACCESS-LIST
Subtype:
Result: DROP
Config:
Implicit Rule
        hits=10, user_data=0x6, cs_id=0x0, reverse, flags=0x0, protocol=0
Result:
input-status: up
output-status: up
Action: drop
edge(config)#
Nagaraja Thanthry Fri, 08/13/2010 - 12:38
  • Cisco Employee,
First of all, you cannot ping an interface IP from workstations connected to
a different interface. The firewall natively blocks that traffic for
security reasons.
I see from your packet tracer that you are trying to ping 10.10.200.1 IP. I
am not seeing that IP in your configuration (may be I am missing something).
Can you please post your current running configuration here?
NT
stephilewis Tue, 10/12/2010 - 11:10
There was two issues I had to add nat statements, also I was connecting through the same switch thus creating a loop.
Added nat statements and segmented networks and all works great!
Thank you to everyone who responded.
Stephen
halooos111 Sat, 10/29/2011 - 00:36
hallo stephe, how did u solve it, i have the same problem as u had?
Tony
