08-12-2010 01:59 PM
Is it possible to write a wild card action-list to re-write ALL URL responses from server to client?
For example, can I do:
action-list type modify http SSL_ACTLIST
ssl url rewrite location *
policy-map type loadbalance http first-match L7_POLICY
class L7CLASS
action SSL_ACTLIST
Also, does SSL URL rewrite only rewrite response from server to client, or can it also rewrite request from client to server?
Solved! Go to Solution.
08-13-2010 11:09 AM
Either way, they will be automatically added if you do not include the quotation marks.
08-13-2010 06:05 AM
Hey Huangedmc,
Use the following instead, that will cover any 302/301 redirect returned from the server and the ace will change it to https from http.
ssl url rewrite location ".*"
And Yes "ssl url rewrite" only rewrites the response from the server.
Joel Lamousnery
TAC Customer Support Engineer
08-13-2010 07:05 AM
With the quatation marks?
08-13-2010 11:09 AM
