Cisco 2821 router won't keep config
Answered Question
Aug 12th, 2010
I have a cisco 2821 router that i'm trying to load a config on and for some reason it will not stay once i reboot it.
I can get the config on and give it a host name and everything that i need but when i reboot it goes back to
router> as the host name and no config on it.What would be causing this problem as this is my first time seeing
this before and thanks for your help in advance.
Correct Answer by Leo Laohoo about 6 years 6 months ago
Check your config-registry using the "sh version" command.  It should be 0x2102 and you can change this using the command "config-registry 0x2102" and a reboot.
Overall Rating: 5 (1 ratings)
Correct Answer
Leo Laohoo Thu, 08/12/2010 - 16:25
scooter817 Thu, 08/12/2010 - 16:57
I will do that as soon as i get to work tomorrow morning and i will let you know if that works.
