ACS File Operation Bulk Upload (Device limit?)
Aug 12th, 2010
I was trying to upload about 250 devices to my ACS server using the file operations option.
I downloaded the template added the devices but when I try the add the 250 devices only 15 would
add at any one time. Why? Does anyone know what the problem might be?
I've modified the template many times to see if the template was the issue however every time it's
limited to 15 devices.
I've already uploaded the devices manually but for future users and myself I'm wondering if anyone knows
the what the reason could be.
Cheers,
Paul
jrabinow Fri, 08/13/2010 - 02:12
There is no built in limit and have seen this working with many more than 15 devices;but cannot say what your issue was without seeing the file you used
One thing you could try is doing an export and can then see file format/contents for all devices
