rme option missing under device updates
aeggers
we have tried to add support for cisco cbs3020 into rme 4.3.
Normally this will be done under common services -> device updates -> rme.
But now we have the problem that rme is listed there. All other lms applications are listed but rme is missing?
Generally rme is installed / up and running.
OS is Windows, LMS is 3.2
Any ideas?
André
5 Replies 5
Joe Clarke
Post your NMSROOT/lib/classpath/com/cisco/nm/xms/psu/conf/tag.properties file.
i've attached the requested file.
rme and cisco view are not listed.
should i manually enter the following lines ?
rme:Resource Manager Essentials
cvw:CiscoView
Yes, shutdown Daemon Manager, add those two lines, then restart.
After adding the line, rme and cv are shown in the device update window.
For cv the device update works fine. But for rme we get some error messages:
Number of Packages Selected for Install : 15
For Product(s) : Resource Manager Essentials
Install Invoked by user : admin
The Package(s) Selected for Install :
Rtr800, SharedInventoryMDS, Cat2960, Cat4000IOS, CatGL3, IAD2400, RtrUBR, SharedInventoryRouter, SharedSwimIOS, Cat3560, Cat3750, SharedSwim2900XL, LibSwim, Rtr2900, Rtr3900
WARNING :  SharedInventoryRouter(2.5.1):Consistency check failed for base package LibInvReports
WARNING :  SharedInventoryMDS(1.5.1):Consistency check failed for base package LibInvReports
WARNING :  LibSwim(2.5.2):Consistency check failed for base package SharedSwimOpticalSwitch
WARNING :  SharedSwimIOS(2.5.1):Consistency check failed for base package SharedSwimRtr800
No package(s) to install for : Resource Manager Essentials
after upgrading rme ro 4.3.1 the device update job works without any problem.
